ᐅ Which surface treatment is suitable for IKEA PLATSA wood?
Created on: 15 Aug 2018 19:27
glavin
glavin
15 Aug 2018 19:27
I am planning to use some IKEA PLATSA units as the basis for custom shelves and want to treat the surface in a way that makes it both durable and long-lasting while keeping it visually appealing. The PLATSA series consists of partially coated chipboard with a melamine-coated surface, which is definitely an important factor to consider when choosing a surface treatment.
I am therefore interested in which methods or products are best suited to enhance or protect the surface without compromising the appearance or the furniture’s structure. My main concerns are:
- How well the treatment adheres to the melamine-coated surface
- Whether a treatment for indoor use is advisable and what options are available
- What preparation steps are necessary to achieve a really good finish
Does anyone have proven methods or practical experience with which surface treatments are truly recommended for IKEA PLATSA wood?
Thanks in advance for your tips!
devon9
15 Aug 2018 20:13
Hello glavin,
I can well understand your question, as IKEA PLATSA furniture is not typical solid wood but made from particleboard with a melamine finish – this is important for surface treatment.
First: On melamine-coated surfaces, adhesion of conventional stains or paints is often problematic because the surface is very smooth and chemically inert. For a lasting result, you should lightly sand the surface beforehand, ideally with fine sandpaper (around 240 grit), to slightly roughen it. Be careful not to sand too much to avoid damaging the coating.
Regarding surface treatment:
- For more protection and a certain wood-like character, water-based acrylic or polyurethane varnishes are suitable. These are easy to apply and protect against scratches and moisture.
- A good alternative is special plastic adhesion primers that improve the adhesion of the topcoat. After that, you can use any paint.
- Oils or waxes are less effective due to the melamine finish, as they do not penetrate well and tend to bead off.
Preparation and application:
- First, clean the surface thoroughly.
- Lightly sand and remove dust.
- Apply adhesion primer (optional but recommended).
- Apply the paint thinly and evenly; several coats may be necessary.
Be careful with solvent-based products: melamine and particleboard do not tolerate all chemical substances.
Summary: Light sanding, use adhesion primer, then apply water-based paint for good protection.
Hope this helps you!
gla-tan
16 Aug 2018 08:42
devon9 schrieb:
When it comes to melamine-coated surfaces, adhesion of conventional stains or paints is often problematic because the surface is very smooth and chemically inert.
That's correct. Therefore: first lightly sand the surface, then apply a special primer designed for adhesion, followed by paint.
Avoid using oils or waxes, as they do not provide lasting adhesion.
This way, you will achieve a durable and attractive finish.
lukin
17 Aug 2018 14:57
glavin schrieb:
I am interested in which methods or products are best suited to finish or protect the surface without compromising the appearance or the structure of the furniture.
That is a very good and important question. I have several PLATSA cabinets at home and would like to share some points based on my experience:
- Unfortunately, melamine-coated surfaces are not suitable for all types of surface treatments; overly aggressive sanding can damage the protective film.
- If you only want to refresh the appearance, thorough cleaning and using furniture polish to mask minor scratches is often sufficient.
- To make the surface more resistant to moisture or light mechanical impact, apply a water-based, matte clear coat in thin layers.
- Light sanding between the first and second clear coat layers results in an excellent final finish.
For the preparation, make sure the surface is free of grease and dust. I also recommend testing on an inconspicuous area or a scrap piece first to see how the material reacts.
I hope this helps. Feel free to ask if you have any more questions!
