ᐅ Which spare parts are most important for Ikea Hemnes furniture?
Created on: 16 Apr 2021 08:17
nuren
nuren
16 Apr 2021 08:17
Hello everyone, I recently purchased some furniture from the Ikea Hemnes series and am considering which spare parts are most important for the durability and maintenance of this furniture. Specifically, I am interested in which components of Hemnes dressers, beds, and wardrobes tend to wear out or need replacement most often, and how to best keep them in stock. Are there particular screws, hinges, runners, or other parts you would recommend having as spare parts? I look forward to your experiences and tips to avoid unpleasant surprises with minor repairs.
Rensan3
16 Apr 2021 08:39
The most important components are definitely the hinges for the doors, as they often become loose or break. Next are the drawer slides, which can squeak or jam. Screws and wall plugs are also useful to have on hand for quick fixes during installation issues.
Laurence
16 Apr 2021 09:04
Hello nuren, your question is very clearly formulated, which makes it easy to respond precisely. The metal hinges on the doors of the Ikea Hemnes series are the most commonly affected components. These wear out over time with frequent use and tend to become loose. Equally important are the drawer slides, as Hemnes dressers often have metal slides with plastic parts that can break. Ordering spare parts directly from Ikea is recommended if you want to ensure longer use. Even if you don’t have any issues yet, it’s worthwhile to have spare screws and wooden dowels on hand, as the joints can sometimes loosen during a move or due to moisture.
kibutar
16 Apr 2021 09:56
Thank you for the well-formulated question. In my experience, the most important spare parts for Hemnes furniture include:
- Hinges: Especially the soft-close versions tend to wear out with frequent use, which can lead to rubber wear or spring issues.
- Drawer runners: It is also advisable to check the plastic rollers, as they can wear down due to dust or heavy use.
- Back panels and wooden dowels: These are often not listed as standard spare parts, but replacing them can be essential if there is warping caused by improper screwing or moisture.
- Screws and bolts: Although small, these can loosen or become bent, particularly for bed frames under higher pressure loads.
Have you had more specific experiences with individual pieces of furniture? That would help to better prioritize which spare parts should really be kept in stock.
nuren
16 Apr 2021 10:12
Laurence schrieb:
The metal hinges on the doors are the most commonly affected parts in the Ikea Hemnes series.
That sounds plausible; I have actually noticed that the doors on one of my cabinets have loosened a bit.
kibutar schrieb:
Do you have more detailed experience with specific pieces of furniture? That would help prioritize which spare parts should really be kept in stock.
So far, I mainly have dressers and a bed—that is, mostly wooden furniture with doors and drawers. The drawers still operate reasonably well, but the bed has some looseness at several joints and no longer feels as stable as when it was new.
Jaime
16 Apr 2021 12:23
I would like to add that in Hemnes beds, the wooden connector dowels between the side panels and the headboard/footboard are often the most underestimated weak points. Over time, these dowels can loosen or break, which affects the bed’s stability. Regular inspection and, if necessary, replacement of these dowels can significantly extend the bed’s lifespan.
Additionally, the metal brackets used to secure some shelving units are useful spare parts, especially under heavy load or frequent rearranging. It is advisable to keep a few of these in reserve as well.
