ᐅ Which screws or materials work best for Ikea PLATSA?
Created on: 18 Oct 2023 08:23
yunus
yunus
18 Oct 2023 08:23
Hello everyone, I am currently working on assembling my new Ikea Platsa system and have a somewhat specific question: which screws or materials do you consider best suited to ensure the stability and durability of the PLATSA system?
I am particularly interested in whether the included screws and wall anchors are truly sufficient for wall mounting, or if it is recommended to use alternative types of screws (e.g., different material grades, lengths, or specialized fasteners).
Especially for higher load conditions or frequent rearranging, a secure hold and sturdy connection are very important to me.
What are your experiences? Do you use other stainless steel screws or have any tips on materials that work especially well with the PLATSA components?
Thanks in advance for your recommendations!
TEOZAR
18 Oct 2023 08:52
Hello yunus, your concern is very understandable and important, especially when it comes to the stability of PLATSA.
The screws supplied by Ikea are usually sufficient for normal use, as they are specifically matched to the products. However, the material is often galvanized steel, which can be prone to rust in humid conditions.
If you plan to move the cabinets frequently or place them in more humid rooms such as the kitchen or bathroom, I recommend stainless steel screws, as they are more corrosion-resistant and therefore last longer.
Regarding length, screws for wall mounting should be at least 6 cm (2.4 inches) long, especially if they are intended to anchor into wall plugs. Here, you can rely on classic universal wall plugs, which are suitable for various wall materials.
Personally, for PLATSA units, I also use wood screws with a large core and coarse thread pitch to make the connection to the wood even more robust.
In summary:
- Stainless steel screws instead of galvanized ones for humid rooms
- At least 6 cm (2.4 inches) length for wall mounting
- Universal wall plugs suitable for the wall type
- Coarse thread screws for wood connections
This way, you are on the safe side.
joro10
18 Oct 2023 09:17
I would simply use the screws provided for the boxes. For mounting on the wall, use stainless steel self-tapping screws, 6-7 cm (2.5-2.75 inches) long. That holds very well.
klo40
19 Oct 2023 11:03
Hello yunus, I’m adding a brief overview to the thread about what to watch for regarding screws and materials for PLATSA:
1. Screws for assembly:
- The original supplied bracket screws are usually sufficient for most installations.
- If you want more stability, I recommend coarse-thread wood screws (e.g., Spax), as they grip better and provide higher load capacity.
- Make sure the screws are not too long, as this can cause the material to split.
2. Wall mounting:
- It’s important to use the right combination of wall plugs and screws suited to your wall type (concrete, drywall/plasterboard, masonry).
- Metal expansion anchors with high-quality stainless steel screws are usually the best choice.
- For drywall/plasterboard, I recommend special cavity anchors, not regular plastic plugs.
3. Material quality:
- Zinc-plated screws are cheaper but can rust in humid conditions.
- Stainless steel screws are more expensive but more durable and especially recommended for kitchen furniture or damp rooms.
4. Assembly tips:
- Pre-drilling screw holes in wood makes screwing easier and helps prevent cracking.
- Use plastic or metal caps on visible screw heads for protection and a clean finish.
Summary:
- For maximum stability with PLATSA: use high-quality Spax wood screws inside.
- For wall mounting: stainless steel screws with appropriate wall plugs.
If you need more information, just ask!
yunus
20 Oct 2023 07:47
joro10 schrieb:
I would just use the screws provided with the boxes.
Thanks for the tip, joro10. I think your assessment is very practical. However, I’m curious if anyone has experienced issues with the standard screws giving way or loosening under heavier loads.
TEOZAR schrieb:
If you plan to move the cabinets frequently or place them in more humid rooms like the kitchen or bathroom, I recommend stainless steel screws, as they are more corrosion-resistant and therefore last longer.
That sounds very reasonable to me. Does anyone know if Ikea actually offers suitable stainless steel screws that are exactly compatible with PLATSA? Or is it better to order them separately?
Also, I would like to know which screw sizes you specifically use to connect the individual PLATSA units together. Are the original ones really optimal?
FLONE41
20 Oct 2023 11:29
Hello yunus, I completely understand your concerns because I also often work with PLATSA myself.
yunus schrieb:
Does anyone know if Ikea actually has suitable stainless steel screws in their range that are exactly compatible with PLATSA?
I haven’t found any stainless steel screws in Ikea’s range that are specifically designed for PLATSA. Therefore, I usually order screws separately from a hardware store or online retailer. Just make sure to use similar lengths and diameters.
Regarding screw sizes: When connecting the individual components, I often use 4x40 mm (1.6x1.6 inch) stainless steel wood screws myself, which has proven to be a good compromise for me. It’s important not to use screws that are too thick to avoid splitting the wood.
And a small tip: If you’re concerned about stability, always mount the cabinets to the wall, as the wall fixture provides really good support.
I hope this helps you!
