ᐅ Which screws are suitable as replacements for IKEA Hemnes furniture?
Created on: 14 Sep 2022 08:37
eugene43Hello everyone, some time ago I bought a piece of furniture from the IKEA Hemnes series, but unfortunately I am missing some screws to fully assemble it. Since IKEA does not always provide the right spare parts or they can be difficult to obtain, I would like to know: which screws can I use as replacements that are technically and dimensionally compatible with the original Hemnes screws? It is important to me to have specific details about thread size, length, and possibly the material, as the furniture needs to withstand considerable stress. Does anyone have experience or precise specifications on which standard screws fit the Hemnes series? Thank you in advance!
The screws for Hemnes furniture are typically machine-made cylinder head screws with an internal hex drive (Allen key). The standard size is M6 with lengths between 40 and 55 mm (1.6 and 2.2 inches), depending on the application within the furniture. It is important to choose a screw with a high strength grade (at least 8.8) to ensure stability. Zinc-plated screws are corrosion-resistant and provide a good appearance. If you need exact measurements, I would recommend measuring an original screw or carefully checking the product description from IKEA.
For reference: The IKEA Hemnes series is known for its solid wood furniture, which is why the screws used are usually metric and machine-made. The most common replacement screw has the following specifications:
- Thread: M6
- Length: between 40 and 60 mm (1.6 and 2.4 inches), depending on the connection point
- Head: cylindrical socket head (Allen)
- Material: steel, either zinc-plated or stainless steel
The reason for using Allen screws is their ease of assembly and strong connection. Make sure to choose the correct length, as screws that are too long can damage the wood. The screws are generally strength class 8.8. For full certainty, you can measure the screws individually since IKEA occasionally uses special lengths.
- Thread: M6
Vinlen schrieb:
The screws for Hemnes furniture are typically machine-made cylinder head screws with an internal hex drive (Allen key). The standard size is M6 with lengths ranging from 40 to 55 millimeters (1.6 to 2.2 inches), depending on their use within the furniture piece.Thank you for the explanation. Could you perhaps specify which lengths are used for which parts? For example, for connections between side panels and shelves or for back panels? The length range varies quite a bit, which sometimes makes it difficult to find the right screws.
eugene43 schrieb:
Could you please specify which lengths are used for which parts?Certainly. For IKEA Hemnes furniture, the usual guidelines are:
- For side panels to frames or cross braces: M6 x 50 mm (2 inches) screws
- For shelves fixed inside the cabinet body: typically M6 x 40 mm (1.6 inches), since the wood is thinner here
- For back panels, smaller screws or nails are often used; hex socket screws are uncommon in this case
These recommendations are based on practical experience when ordering replacement parts. The important point is that the screw should not penetrate through the entire material thickness to avoid damage.
