ᐅ Which screws are best to use for Ikea Platsa furniture?
Created on: 1 Feb 2020 09:17
pokuga
pokuga
1 Feb 2020 09:17
I am currently considering using suitable screws for assembling my Ikea Platsa furniture. The screws provided with the furniture are not ideal for some parts, such as attaching the back panels or for modifications I am planning to make.
My main question is: Which screws work best for the different connections in Ikea Platsa furniture? I am interested in whether it is better to use replacement screws of the Ikea type or if more traditional furniture or wood screws also work without issues. Additionally, I would like to know
- which screw sizes are recommended (length, diameter),
- which screw type (chipboard screws, sheet metal screws, wood screws) offers the best stability and durability,
- and whether specific screw heads (Phillips, Torx, hex) are advantageous.
My goal is to achieve a durable and secure result without damaging the furniture structure. So I want to avoid screws that might split the material or fail to hold properly.
I look forward to your experiences and recommendations!
jordanvin
1 Feb 2020 10:05
pokuga schrieb:
My main question is: Which screws are best suited for the different connections in Ikea Platsa furniture?
Hey, great question! I’ve assembled several Platsa cabinets myself and can share some practical advice:
- The best choice is chipboard screws with a flat head, 4 mm diameter and 30–40 mm (1¼–1½ inch) length. These are strong enough for the thinner panels.
- For the back panels, you can also use standard Phillips wood screws. Since the back panels are usually thin, 25 mm (1 inch) length is typically sufficient.
- I’d recommend screws with Torx heads because they slip less easily and provide better grip.
So don’t worry if you deviate a bit from the Ikea screws—the commonly available chipboard screws work really well! Keep it up, you’ve got this 🙂
RonJarrett
1 Feb 2020 11:42
Additional information:
Ikea Platsa furniture is mainly made from particleboard with a melamine coating, so particleboard screws are preferred. These screws have a special thread design that cuts into the material better and provides higher holding strength.
- Screws with a diameter of 4 mm and a length between 30 to a maximum of 50 mm (1.2 to 2 inches), depending on the thickness of the component, are recommended.
- For thin back panels, 25 mm (1 inch) screws are sufficient, as longer screws might damage the material.
- Avoid using sheet metal screws, as they are not suitable for wood-based materials and can reduce stability.
- Torx heads are more ergonomic than Phillips heads because they slip less. They also make it easier to tighten screws with higher torque.
Important: Pre-drilling is usually not necessary for Platsa, as particleboard screws are self-tapping, but caution should be exercised when making modifications to avoid causing cracks.
difepeo
1 Feb 2020 12:33
RonJarrett schrieb:
Screws with a diameter of 4 mm and a length between 30 and a maximum of 50 mm (1.2 and 2 inches) are recommended
I wouldn’t fully agree with that, especially regarding the length. Screws that are 50 mm (2 inches) long can be more stressful than necessary for thinner boards and may cause tension in the material if used incorrectly.
In my tests, screws that are too long tend to create microcracks along the material’s stress limits or lift the veneer in melamine boards, which reduces durability. Therefore, the screw length should be carefully matched to the actual board thickness.
Additionally:
- Have you ever tested self-tapping screws with dry wall thread or full thread?
- What about using countersunk screws versus flat-head screws? This significantly affects how components are joined.
I believe that the commonly recommended standard should not be taken as dogma; it’s worth looking at things more critically.
pokuga
2 Feb 2020 08:58
difepeo schrieb:
So the length should be closely matched to the actual thickness of the panel.
Thanks for the advice! You're right, I definitely don’t want to damage the material. Most of my Platsa parts have a thickness of 16 mm (5/8 inch), but the back panel is really thin, around 3-4 mm (1/8–5/32 inch).
RonJarrett schrieb:
Pre-drilling is usually not necessary with Platsa, since chipboard screws are self-tapping.
Would pre-drilling be particularly important if retrofitting with different screws? And what about the surface—if I change the screws, are there any tips on how to best avoid or cover the overhead marks left by the screws?
Also, a detailed question: For connecting the base and the cabinet carcass, should I use shorter or longer screws? The material thickness there is somewhat greater.
I hope this doesn’t complicate things too much, but I want to be on the safe side.
sonplo
2 Feb 2020 10:44
Regarding the length: A good rule of thumb is to use screws no longer than two-thirds of the thickness of the board. For 16 mm (5/8 inch) thick boards, this means about 10 mm (3/8 inch) should remain embedded in the wood.
For the base connection, longer screws can be used since the pressure on the joint is higher there; 40 mm (1 5/8 inch) screws should work well.
Pre-drilling is only necessary in very delicate areas or if you want to achieve high precision.
For the surface: It is best to use countersunk screws so that the screw heads are flush, making it easier to paint over or cover these spots later on.
Chipboard screws with partial threading are generally better than fully threaded screws because they reduce tensile stress.
My recommendation: Use high-quality chipboard screws, for example, with a Torx drive, as they provide better grip and cause less damage.
