ᐅ Which screwing techniques prevent loose connections in BILLY?
Created on: 17 Mar 2020 09:23
Dra-fu48
I have recently assembled several Billy shelves and noticed that screw connections tend to loosen quickly with frequent use or load. Therefore, I would like to ask: What fastening techniques are especially effective in preventing loose joints in Billy shelves?
I’m not only referring to the choice of screws but also the assembly process itself, such as tightening torque, pre-drilling, the use of wall plugs or additional reinforcements. I’m particularly interested in how to achieve strong, durable connections that don’t loosen again after a short period.
Are there specific tips that work particularly well for this type of furniture, maybe based on personal experience?
Thanks in advance!
Thanks in advance!
I would like to share that I have sometimes cushioned the dowel points on my Billy shelves using ordinary household rubber, placing rubber washers between the screws and the board.
In my experience, this helped reduce the vibrations that otherwise cause screws to loosen on their own.
However, I admit that this is more of a DIY solution and works well if you have good tools, but it is not necessarily the easiest method.
After reading about the Minifix issue here, I now pay even more attention to carefully and repeatedly retightening the cam lock screws – this seems to be the best compromise.
I can well understand the frustration when screws start to loosen in furniture like Billy.
In my experience, regularly tightening the screws is the most important step. Of course, no technique can help if the shelf is constantly moved or overloaded.
That’s why I try to ensure the shelf is level and stable during assembly, as vibrations have a negative effect on screws over time.
A small tip from me: using furniture pads or felt gliders under the sides of the shelf helps to better absorb vibrations from the floor.
Dra-fu48 schrieb:
The tension bolts tend to loosen very quickly, probably because it’s difficult to tighten them properly again.One more technical note on the Minifix connector used in Billy: This connector joins the panels through a sleeve and a screw that is threaded into this sleeve. The problem is that the clamping force heavily depends on the condition of the material around the hole, and the screw itself is usually quite short.
This causes the grip to weaken with frequent use. One way to secure the connection is to apply thread-locking adhesive to bond the threads, or to use stronger Minifix sleeves if possible.
Additionally, the material around the hole can be stabilized— for example, with small wood glue repairs—if it is slightly swollen or damaged.
I’m wondering if others have experience with Minifix alternatives that prove effective in practical furniture failures?
