ᐅ Which screwing techniques prevent loose connections in BILLY?
Created on: 17 Mar 2020 09:23
Dra-fu48
I have recently assembled several Billy shelves and noticed that screw connections tend to loosen quickly with frequent use or load. Therefore, I would like to ask: What fastening techniques are especially effective in preventing loose joints in Billy shelves?
I’m not only referring to the choice of screws but also the assembly process itself, such as tightening torque, pre-drilling, the use of wall plugs or additional reinforcements. I’m particularly interested in how to achieve strong, durable connections that don’t loosen again after a short period.
Are there specific tips that work particularly well for this type of furniture, maybe based on personal experience?
Thanks in advance!
Rensan3
17 Mar 2020 12:00
Pre-drill, use appropriate screws, and avoid overtightening.
Retighten regularly.
Done.
Laukau5
17 Mar 2020 13:45
I would like to take the opportunity to explain in more detail the technical background and options that help keep screw connections stable in particleboard furniture like Billy.
1. Material properties: Particleboard is relatively brittle and not very elastic due to the glued wood chips and its pressing density. Therefore, traditional wood screws, as used in solid wood, are often not ideal. The reason is that the material can break out around the thread under excessive stress.
2. Particleboard screws: These special screws have threads that are significantly deeper and sharper, distributing the load more effectively. Additionally, the shank area is often reduced, which lowers tensile forces.
3. Pre-drilling: It is important not to choose too large a drill hole. A general guideline is about 70% of the screw diameter. Pre-drilling prevents material splitting while allowing the screw to be inserted optimally.
4. Screw-in technique: Screws should be driven in slowly with low force to avoid overloading the material. A cordless drill with adjustable torque is the best tool for this.
5. Securing: Screw-locking lacquer or a drop of wood glue in the hole can improve clamping. However, keep in mind that glue makes disassembly more difficult.
6. Alternatives: For heavily loaded areas, fittings, anchor bolts, or metal brackets can also be suitable.
If you can describe more precisely which connections in your Billy are particularly problematic, I would be happy to offer more targeted advice.
Dra-fu48
17 Mar 2020 14:05
Laukau5 schrieb:
If you can describe more precisely which joints in your Billy are especially problematic
Thank you for the detailed post!
The joints that tend to loosen most often for me are the side panels attached to the bottom and the back panel fastened with the small cam screws. The cam screws tend to loosen very quickly, probably because it’s difficult to tighten them properly without damaging the material.
For the side panels, I usually use the supplied chipboard screws, but even those often don’t hold well. I want to focus on improving the screwing technique before adding any extra fittings, as I want to maintain the original appearance and function.
KODAN32
17 Mar 2020 14:24
Dra-fu48 schrieb:
The tension screws tend to loosen quickly, probably because they are difficult to tighten properly
This is a well-known issue with the so-called "Minifix" connector commonly used in Billy-style shelving units.
My advice: When assembling for the first time, tighten very carefully and precisely, making sure not to damage the Minifix dowel inside. After that, it is recommended to apply a small drop of wood glue into the hole or alternatively use rubber washers under the connecting elements to reduce vibration and thus prevent loosening.
Also: Don’t just fully tighten the tension screws; then loosen them slightly by about a quarter turn – this relieves stress and can help prevent loosening.
This method has usually provided the most stable results for me so far.
CORYGAU
17 Mar 2020 15:01
KODAN32 schrieb:
Also: Don’t just tighten the tension screws fully, but then loosen them slightly by about a quarter turn – this reduces tension and can prevent the screws from loosening later.
That seems paradoxical to me, but in fact, pretension in connections often has a negative effect.
I would like to add to this advice: It is also important to check and, if necessary, retighten the screws after a few days of initial load, because the material can still settle.
I’m also wondering if any of you have experience with alternative locking methods, such as self-tapping threaded inserts or so-called “insert nuts” for greater stability?
O
ottilie
17 Mar 2020 15:28
CORYGAU schrieb:
I’m also wondering if any of you have experience with alternative fasteners, such as self-tapping threaded inserts or so-called “insert nuts” for increased stability?
Good question!
I have actually done some experiments with insert nuts that can be screwed into larger holes. However, you quickly notice that this becomes quite complicated with Billy-style shelves, and the joints end up looking “overengineered.”
I think for home use, careful screwing technique and occasionally using thickened wood glue where screws don’t hold well is usually sufficient.
If maximum durability is important, it’s better to opt for solid wood furniture or metal shelving.
Sometimes less is more ;-)
