ᐅ Which screwdrivers are best suited for assembling Ikea PLATSA units?
Created on: 6 Dec 2020 09:37
kaste
kaste
6 Dec 2020 09:37
Hello everyone, I am about to assemble an Ikea Platsa wardrobe and am wondering which type of screwdriver is best suited for this.
The instructions recommend typical Phillips screwdrivers (PH2), but I have also often heard of Torx or hex (Allen) bits being used for furniture like this. Since the screws in PLATSA are often precisely designed for load capacity and fit, I want to avoid using either the correct or incorrect tool if it could damage the screws or the furniture itself.
What has been your experience? Are classic Phillips screwdrivers the best choice here, or do professional DIYers usually prefer specialized bits? Are there any recommendations regarding the size or quality of the tools, or perhaps alternatives that make assembly easier? I appreciate detailed tips and personal experiences!
piflo
6 Dec 2020 10:52
kaste schrieb:
What experiences have you had? Are classic Phillips screwdrivers the tool of choice here, or do professional DIYers tend to use specialized bits?
I know the feeling when you’re assembling new furniture and are afraid of damaging the screw head. With PLATSA, I’ve mostly had good experiences using a high-quality Phillips PH2 screwdriver. Having a clean blade with sharp, well-fitting edges is crucial—not just the size alone. Cheap screwdrivers tend to slip, which I’ve often experienced and found frustrating. Sometimes I’ve also used a Torx bit when the screws allow it, as this transfers force better. But basically, the classic tool is sufficient.
Of course, if you’re unsure, it’s better to use a screwdriver set with multiple bits and try out what fits best before turning loosely or abruptly. This saves nerves and protects the screw.
O
olivernu
6 Dec 2020 13:08
As a general recommendation for assembling Ikea PLATSA and similar furniture, consider the following approach:
- Use a good quality Phillips screwdriver size PH2, preferably with a magnetic tip to make handling easier.
- A bit driver with adjustable torque is especially helpful if you’re assembling many screws in succession, as it speeds up the process and protects the screws.
Most of the screws for PLATSA use Phillips heads. You will rarely find Torx or hex (Allen) heads there. It is important that the screwdriver fits precisely, as even slight misalignments can cause wear on the screw heads.
Alternatively, you can use a cordless drill with torque control, which is recommended for longer assembly tasks; however, be sure to select the correct bit and keep the torque setting low to avoid damaging the material.
pauPierce
7 Dec 2020 07:49
Here is a detailed assessment to supplement the discussion:
PLATSA often uses furniture fittings and fasteners designed for precise tightening with the appropriate tools. In my experience, PLATSA primarily uses Phillips PH2 screws, as already mentioned. Key points are:
- The tool should have an exact fit, absolutely free of wear or rounded tips.
- Cheap screwdrivers can quickly damage the screw, which later leads to weak joints or stripping of the screw head.
- If using a cordless drill, use a bit holder with a magnetic ring to securely hold the screw head. Set the torque level to 1 or 2, which is sufficient.
Other tips:
- Some components are fastened with hex screws, so having a set of hex (Allen) bits can be helpful.
- Ensure ample lighting – poor visibility often causes errors when inserting the screwdriver.
- Always insert screws straight, avoiding lateral forces, so everything works smoothly.
I have also had good results when having the correct bits ready for felt or metal connectors, as these can differ somewhat from the standard. If you are facing a set with many small screws, it is worthwhile to have a comprehensive bit set that specifically includes PH2, PZ2, Torx, and hex (Allen) bits.
LuMarcel43
7 Dec 2020 22:23
olivernu schrieb:
The screws used in PLATSA are mostly Phillips head.
That’s clear so far, but I always wonder: why doesn’t Ikea consistently use a Torx system? The torque factors when tightening and the lower risk of stripping clearly favor Torx.
Another point is the quality of the tool. Especially with Phillips heads, tool quality seems crucial – cheap tools can seriously damage the screw heads.
Therefore, I would recommend: if you frequently build or assemble furniture over a longer period, it’s worth investing in a well-made bit set including Torx. For occasional PLATSA assembly, a PH2 screwdriver should be enough, but with appropriate care.
Have you actually found Torx screws in your assemblies, or only Phillips heads? The manufacturing process could influence the type of screw used.
