ᐅ What child safety measures can be effectively installed on Ikea Besta doors?
Created on: 6 Apr 2021 08:37
Len63
Len63
6 Apr 2021 08:37
I would like to know which safety measures work well on the doors of the Ikea Besta system to prevent small children from opening them on their own. I am mainly looking for a child-friendly, practical, and sturdy solution that is easy to install and does not leave significant marks on the material.
Does anyone know of specific safety latches, child locks, or other devices that fit particularly well with the hinges and doors of the Besta system? Tips on simple methods or DIY options are also welcome, especially if they still allow easy access for parents.
Thank you in advance for your recommendations and experiences!
TEOZAR
6 Apr 2021 09:22
Hello Len63,
From my experience, when it comes to Ikea Besta doors, I recommend using so-called cabinet door locks, which are usually attached with adhesive pads or screws. It’s important to ensure that the locks do not stick too aggressively to the surface, so there are no visible residues if you want to remove them later.
Many parents use magnetic locks that can be opened from the outside with a small key or a magnetic tool. The advantage is that children cannot open the doors, while adults still have easy access. These locks are often very discreet and do not significantly affect the design.
If you prefer a simpler solution, mechanical latches installed at the corners of the doors can also work, opening with a simple tilt motion. These are inexpensive and easy to install.
Finally, a reminder: always make sure there is enough clearance around the hinges so that adults can operate the doors easily while keeping children securely out.
I hope this helps!
KUDAISY
6 Apr 2021 13:45
Hello Len63,
I would like to add some structured tips that might help you choose a child-safe lock for Ikea Besta doors:
- Magnetic door locks:
- Advantages: Invisible from the outside, no tools needed for installation
- Disadvantages: Requires a special opening tool, may be complicated for several family members
- Clamp or latch locks:
- Advantages: Easy to use, prevent unwanted opening
- Disadvantages: Not always ideal for all Besta door types, sometimes installation can affect the appearance
- Child safety locks with strap protection or rubber bands:
- Advantages: Protect against pinching and easy to use
- Disadvantages: Not always secure enough against very curious children
- DIY solution with hook-and-loop fasteners or adhesive strips:
- Advantage: Low cost and easy to remove
- Disadvantage: Less durable, may not be secure enough for strong children
A common mistake to avoid is mounting too close to the hinge or edge, which can make access difficult for adults or lead to an unstable result. I would also recommend considering multiple methods and possibly combining several for increased safety.
If you like, I can also provide exact models that I have successfully used.
glamo
7 Apr 2021 10:16
Len63 schrieb:
I would like to know what safety measures can be effectively applied to the doors of the Ikea Besta system to prevent small children from opening them independently.
This is a very sensible and important question, especially for Besta, which often features relatively thin wood or MDF doors with a melamine coating. The material requires careful consideration when choosing safety devices because heavy drilling or screwing can damage the surface and cause the doors to swell.
In my experience, magnetic locks with strong adhesive work best because they don’t leave visible holes. You should ensure the adhesive connection can be undone if replacement or removal is needed. A common mistake is applying too much pressure during installation or not properly cleaning the doors beforehand, which causes the adhesive to lose its hold.
Another option is corner latches installed on the inside of the doors. Here, I recommend using screws with a small diameter and pre-drilling to avoid damaging the material. This creates a very durable solution that is also tough against persistent little hands.
If you want to secure the door handles directly, there are strap or band lock combinations that can be mounted on the side. These provide very flexible handling.
I would also be interested to know whether your doors are sliding doors or traditional hinged doors with handles, as the measures may differ depending on this.
