ᐅ Which panels are suitable for cladding IKEA Platsa units?
Created on: 4 Jun 2018 08:23
Nehau
Nehau
4 Jun 2018 08:23
I am currently planning to enhance the appearance of my IKEA Platsa wardrobe and am looking for suitable panels for cladding. I am interested in both materials and manufacturing techniques that are compatible with the modular dimensions of Platsa and ensure a durable, high-quality finish. It is also important that the panels are easy to install without affecting the basic structure of Platsa.
What types of panels, such as MDF, HPL, solid wood, or other materials, have you used or would you recommend? Are there any specific finishes or manufacturers that have proven to be reliable? I look forward to your details and experiences.
sanpar58
4 Jun 2018 09:15
Hello Nehau,
For cladding IKEA Platsa units, I especially recommend MDF panels with a melamine or foil finish. These are sturdy, easy to cut and adjust, and come in a wide range of colors and textures. MDF is also lighter than solid wood and absorbs moisture better than particleboard, which is important during installation.
I used light-colored panels with a matte foil finish myself, which I simply screwed onto the back wall. It’s important to ensure the panels are not too thick; otherwise, the doors won’t fit properly.
Additionally, you can use moldings or adhesive profile systems to create a clean edge. If you like, I can also give you some tips on cutting.
FAZAR
4 Jun 2018 11:02
To determine the most suitable panels for cladding the IKEA Platsa system, we should first clarify the functional requirements:
- Dimensional accuracy: The panels must fit precisely to the modular dimensions of Platsa; deviations can cause issues with door closing or overall stability.
- Surface properties: A durable material such as HPL (High Pressure Laminate) is recommended, as it is scratch-resistant and water-repellent.
- Ease of installation: Panels should be workable with standard tools and easy to attach, for example using screws or clamping profiles.
Regarding materials, I recommend the following categories:
- MDF boards (medium-density fiberboard) with laminated surfaces or sealed with paint, as they are cost-effective and easy to work with.
- HPL panels: These are more expensive but offer an industrial-grade surface that is highly durable and may also include fiberglass reinforcement.
- Solid wood panels, if you want a natural look and are prepared to work with wood preservatives.
Keep in mind that MDF panels can be available in formaldehyde-free versions depending on quality, which is important for indoor furniture. For cutting, I recommend using a precise table saw or having the panels cut at a professional supplier to ensure exact dimensions.
I would also be interested to know your planned surface colors, as this influences the material choice.
What are your specific ideas regarding the appearance?
Nehau
4 Jun 2018 12:48
FAZAR schrieb:
I’m also interested in your planned surface colors, as that plays a role in material selection.
Good point, thanks for asking. I’m leaning towards a matte, light surface in white or cream to make the space appear larger. Would a laminated MDF panel be a good choice here, or would painting be better? I’m concerned that painting might cause unevenness or make the surface less durable. At the same time, I want to avoid panels that are too delicate, since the cladding will need to withstand contact with lively children’s hands. Does anyone have experience with laminated surfaces in such light colors, particularly regarding maintenance and durability?
RAKLO
4 Jun 2018 14:35
Nehau schrieb:
Does anyone have experience with laminated surfaces in such a light design, especially regarding care and durability?
In my opinion, laminated MDF panels are very well suited, especially for light designs. They are resistant to moisture and scratches if you use a high-quality laminate. However, you should carefully protect the edges, as damage from impact or moisture is more likely to occur there.
Edge profiles or special edge banding also offer an advantage in making the panels more durable. Cleaning agents should be mild and silicone-free.
Alternatively, powder coating is an option, which is also very durable, but it is usually expensive and requires professional application.
KAMERON
5 Jun 2018 07:54
sanpar58 schrieb:
MDF panels with melamine or laminated surface
Following sanpar58’s recommendation, I would like to add that laminated MDF boards with a thickness of about 6 to 10 mm (0.24 to 0.39 inches) are ideal. Thinner boards may warp or break when screwed, while thicker ones could affect the modularity of the door mechanism.
An important detail is the mounting: it is advisable to install the cladding using spacers or concealed screws. This way, the panel cladding does not rest directly on the floor, preventing moisture damage.
The combination of a laminated surface and proper installation results in a durable and visually appealing solution.
