ᐅ Which materials are suitable for custom cladding of IKEA Platsa units?
Created on: 15 Oct 2015 20:03
tufan57Hello everyone,
I am planning to customize the exterior of my IKEA Platsa unit and want to use materials that are both durable and visually appealing. My question is: Which materials are best suited for custom cladding of IKEA Platsa, if you prioritize durability and ease of handling, while also aiming for a modern design and straightforward installation?
I look forward to your experiences and recommendations, including any advantages and disadvantages of the different materials.
A very well-considered question that is likely to interest many.
When choosing cladding for IKEA Platsa, I recommend first distinguishing between different material groups:
- Wood-based panels (e.g., MDF, HDF, plywood) are the most popular due to their stability and ease of handling. MDF, for example, is easy to paint or laminate but is not very water-resistant. Plywood is more durable but often more expensive.
- Laminate panels or melamine-coated particleboard are very low-maintenance and scratch-resistant but more challenging when cutting and processing edges.
- Films or adhesive veneers are a cost-effective option for surface changes but are not suitable if you want truly thick claddings.
- Metal claddings or aluminum profiles are robust and modern but more complex to work with, better suited for specific design concepts.
For installation and cutting, depending on the material, a circular saw with a fine-tooth blade (wood-based panels) or a special laminate cutter or metalworking tool is recommended. The choice of adhesives or screws is also important because some materials are sensitive to moisture or mechanical stress.
Do you already have concrete ideas regarding the style or planned DIY skill level?
Hey,
I think it’s perfectly fine to have a bit of fun with the look in a project like this. 😉
If you don’t want it to be too heavy, I would recommend using thin MDF panels with wood veneer foil. They look really nice and are relatively easy to work with and glue.
You can also add some great accents with paint – for example, matte tones for a modern feel or high-gloss lacquer if you want a real eye-catcher.
And if you want to change something later, you can simply remove or sand down the cladding. Pretty practical, right?
Of course, it’s not the most durable material, but absolutely sufficient for living areas.
For structured work, I recommend thin MDF panels with a thickness of 6 to 10 mm (approximately 0.24 to 0.39 inches), as they offer an optimal balance of stability and flexibility.
Before painting, the surface should be thoroughly sanded and primed to achieve an even finish.
Alternatively, HDF panels can be used, as they are more densely compressed and provide particularly smooth surfaces; however, they are more expensive and harder to work with.
For a waterproof and scratch-resistant solution, coated RIP or CPL panels are suitable, but these are not easy to process with basic DIY tools and are more appropriate for professional use.
