ᐅ Which materials are suitable for a custom Ikea PLATSA enclosure?
Created on: 11 Nov 2016 09:12
Bisibe
Bisibe
11 Nov 2016 09:12
I’m planning to customize the exterior of my Ikea Platsa wardrobe and am looking for suitable materials to do so. It is important to me that the material is durable and visually appealing, but also easy to work with—the covering should not only look good but also be practical.
I’m particularly interested in factors such as surface texture, weight, maintenance requirements, and of course the ability to attach the material neatly to the Platsa without too much effort or risking damage.
Therefore, my question is: Based on your experience, which materials are best suited for a custom Platsa covering? I would appreciate insights on the advantages and disadvantages of each, tips for working with them, or common mistakes to avoid.
Looking forward to your opinions and experiences!
Sepele
11 Nov 2016 10:35
Hello Bisibe,
Regarding your question: There are several materials that work well for a custom PLATSA covering. I would recommend using the following construction as a guideline:
- MDF boards: Very easy to work with, can be painted or laminated individually. Choose a suitable thickness depending on the load, typically 6-12 mm (0.24-0.47 inches).
- HDF boards: Harder than MDF, a bit more expensive, but more durable and smoother. Ideal for furniture coverings.
- Plywood: Very stable, especially birch or beech, easy to sand and paint. However, it is somewhat more expensive and heavier.
- Plastic panels (e.g., HPL or acrylic): Especially low-maintenance and available in various colors and finishes. Bonding or screwing these panels can be more challenging.
Common mistake: Choosing boards that are too thin, causing warping or instability. Also, for painted surfaces, ensure good priming and work quickly to avoid unevenness or bubbles.
I hope this helps you for now!
matthewon
11 Nov 2016 11:01
Sepele schrieb:
Typical mistake: choosing panels that are too thin, which then warp or become unstable.
I find it interesting that many people ignore this and then complain that their "custom" Ikea system looks cheap. If you really want to create a high-quality cladding, you shouldn’t save on materials but rather opt for well-finished wood instead of foils or particleboard.
Most people here overestimate the effort involved and underestimate the impact of good materials. PLATSA is already a solid system; a high-quality exterior should reflect that.
V
van_pe
11 Nov 2016 12:28
Carve, paint, or veneer MDF or plywood. Plastic is more suitable for wet rooms. Consider weight for large surface areas.
TARNE
12 Nov 2016 08:47
Hey, I find this topic really exciting! I completely covered my PLATSA with pre-painted MDF panels – easy to install, looks very elegant, and you can even choose different colors! 😍 It also feels very sturdy, and since it’s painted, maintenance is really simple. Just wipe it down and you’re done! If you decide to paint it yourself: patience is key here, as it will result in a really smooth surface. 🙂
Good luck with the covering! You can do it!
silako
12 Nov 2016 10:15
TARNE schrieb:
I fully covered my PLATSA with pre-finished MDF panels – easy to install, looks really elegant, and you can even choose different colors!
Absolutely, MDF is versatile, but do you have any concerns about moisture resistance? Especially for PLATSA units placed in kitchens or bathrooms, MDF might not be the best option unless you use moisture-resistant variants or apply appropriate coatings.
van_pe schrieb:
Plastic is better for wet rooms.
Plastic materials like HPL panels are not only moisture-resistant but also scratch-resistant; however, working with them is more complex – precise cutting and special adhesives or fastening techniques are needed due to the hardness of the material.
I would recommend carefully considering the specific installation environment before making a decision.
