ᐅ Which Ikea Metod countertop materials are heat resistant?
Created on: 26 Jun 2020 08:12
Paupa
Hello everyone, I am currently planning my new kitchen using the Ikea Metod system and am trying to choose the right countertop. For me, heat resistance is especially important because I often place hot pots and pans directly on the surface. I am therefore very interested in which Ikea Metod countertop materials are considered heat resistant or what temperatures they can generally withstand without damage. Does anyone have practical experience or reliable information on which materials can be safely used around cooktops and work surfaces? Recommendations that go beyond simple surface protection measures are also welcome. Thanks in advance for your support!
cecile65
27 Jun 2020 11:07
So, in summary: laminate and veneer are never heat-resistant enough to place pots on directly. Quartz stone or, even better, natural stone is the only real solution if heat is regularly applied directly.
ixlu1
27 Jun 2020 12:48
Exactly! Tip: It’s better to invest in good-quality materials right from the start, because you will only regret it more later on. Heat-resistant countertops are worth every dollar! 😊
Paupa
28 Jun 2020 08:15
Thanks to everyone for the detailed and often very helpful information! Your insights have made me more confident that my priority should be quartz countertops, even if I need to allocate a bit more in my budget. Still important for me: Ikea distinguishes between different finishes and materials for Metod, and I have in mind that there are also HPL-coated panels. Does anyone have experience with whether HPL might offer better heat resistance compared to traditional laminate or veneer?
Sikla
28 Jun 2020 09:56
HPL (High Pressure Laminate) is usually the standard surface coating on particle board for Ikea Metod. Its heat resistance is slightly better than regular laminate but still requires protection with trivets or hot pads. It is not suitable for placing hot pots directly on it.
theo63
28 Jun 2020 11:23
Paupa schrieb:
Has anyone experienced whether HPL offers any advantage over traditional laminate or veneer in terms of heat resistance?
Not significantly. HPL is more resistant to scratches and moisture, but its thermal resistance is similar to laminate since the core materials remain the same. Temperatures above 100°C (212°F) can cause problems. For true heat resistance, you need mineral-based boards.
NUGRANT
28 Jun 2020 14:01
My tip: better to go straight for quartz stone or Dekton! It pays off in the long run – no more worries and great appearance! 😍
