ᐅ Which materials are suitable alternatives for IKEA Platsa back panels?
Created on: 26 Dec 2015 18:47
ralfga
Hello everyone, I have a question that might have concerned some of you before: What materials are suitable as alternative back panels for IKEA Platsa cabinets? I’m looking for a solution because I’m not satisfied with the standard back panels – they are too thin, not very stable, and somewhat fragile, especially if you want to use the cabinet differently or enhance its appearance. It is important to me to find a back panel that is easy to cut and attach, as stable as possible, and ideally resistant to moisture in case the cabinet is placed in the kitchen or bathroom. Does anyone have experience with alternative materials, such as wood panels, MDF, HDF, plywood, or others? Are there particular criteria or tips for working with these materials? I look forward to your advice!
ritotar
27 Dec 2015 19:12
noge58 schrieb:
I bought 5mm (0.2 inch) plywood and painted it myself.
Sounds like a great DIY project! 😄 When finely sanded and coated with stain or paint, you not only get stability but also a very personal look – so if you want more individuality, plywood is a real winner. And combined with a moisture protection layer, it will last a long time!
glamo8
28 Dec 2015 08:04
One more tip: If someone is looking for a very simple solution, you can also use sturdy hardboard (HDF). It is more affordable than plywood and easy to cut. It is available in different thicknesses – 4 mm (0.16 inches) is usually sufficient.
kumau
28 Dec 2015 09:28
I used simple 3 mm (1/8 inch) MDF back panels for my Platsa cabinet. They are sturdy, easy to work with, and affordable. When sealed with edge paint or veneer, they also hold up well in bathroom areas, provided there is not excessive moisture.
Declan55
29 Dec 2015 13:55
Big question, thanks for the thread! 🙂 I used plywood panels (6 mm (1/4 inch)) for my project. They are really stable and sturdy, but you have to be very precise with the fit; otherwise, installation gets tricky. The back panel holds the cabinet together very well, and when painting, you can really get creative with color and finish. For me, this is the best solution!
