ᐅ Which interior fittings are particularly practical for PAX?
Created on: 18 Aug 2016 09:37
Lutusin
Lutusin
18 Aug 2016 09:37
I would like to start a focused discussion on the topic: Which internal tools are particularly practical and useful in PLAXIS for working efficiently and accurately during the modeling process? I am especially interested in which standard and possibly also specialized tools you prefer for internal use to define geometries, model interfaces, or accurately represent material transitions.
My goal is to compile a well-founded collection of proven internal tools that not only work well together in terms of control but also support the workflow throughout various stages of the work. Are there tips for certain favorites when dealing with more complex components or multilayer geometries? Any advice on common sources of errors when using internal tools would also be very helpful.
I’m looking forward to your experiences, preferably with examples. Which internal tools have proven most effective in your practice, and which less so? Where do you see the limitations of the available tools for internal modeling?
Lyndon55
18 Aug 2016 12:03
Good question, there are several important points to consider.
I will break down my answer into simple steps so that everyone can easily follow which internal inserts I would recommend:
- Geometric internal inserts: Functions like "Create Inner Contours" or "Add Boundaries" are very useful here. They allow precise definition of interior spaces by delineating the inner room area.
- Interface tools: When modeling interfaces between different materials, "Interface Layer" inserts are essential. They help define transitions cleanly and better account for any interaction effects.
- Material assignments inside: The ability to assign specific material parameters within a defined interior space greatly facilitates simulation. It is important to use the correct level or volume linking here; otherwise, unintended deviations in results may occur.
Common mistakes include overlapping internal inserts, which disrupt calculations, or unintentionally leaving edge surfaces open within the interior, leading to undesired boundary conditions later on.
In summary, the most important internal inserts for me are those that ensure clearly separated rooms, well-defined transitions, and precise material assignments. Mastering these allows for simulations with fewer errors and higher accuracy.
Rosan
18 Aug 2016 13:56
For Pax, interior inserts that provide clear separations are especially important.
- Create interior contours
- Model material transitions cleanly
- Define interfaces using special layers
Otherwise, the simulation becomes inaccurate or unstable.
benonon
19 Aug 2016 08:42
The question of the most practical interior inserts for PAX is quite complex and requires consideration of the specific project context. Generally, I would take the following points into account:
1. Workflow Integration: Interior inserts should integrate seamlessly into the existing modeling process without requiring additional conversion steps.
2. Complexity Reduction: Especially with complex, multi-layered components, interior inserts that provide standardized tier versions or templates are helpful for time-saving reuse.
3. Precision Control: Tools that allow fine-grained adjustment within the interior area, for example to represent localized changes in material behavior, are essential.
A practical example: When working with sandwich constructions, I use multiple interior inserts in parallel—one for the outer shell, one for the core materials, and a third for transition layers and connecting elements. It is important here to avoid overlaps and to clearly label the layers.
Rosan schrieb:
For PAX, interior inserts that provide clear delineations are especially important.
I would fully agree with that, although the level of precision depends greatly on the final goal of the simulation. Is it just about rough estimates or detailed load predictions?
Which interior inserts are considered standard for you therefore strongly depends on the intended use.
By the way, which version of PAX are you using? The functionalities of the interior inserts have evolved significantly in recent releases.
Renka
19 Aug 2016 11:54
It’s interesting that everyone here only talks about clear boundaries.
Lyndon55 schrieb:
Typical mistakes include overlapping interior inserts, which disrupts the calculations.
I argue that creative overlaps can be used effectively if you know exactly what you’re doing. Interior inserts don’t necessarily have to be strictly separated; they can interact dynamically to model complex composite connections.
Sure, this requires more experience, but in my opinion, the potential here is rarely utilized. People often talk about ‘pragmatic,’ meaning rather simple inserts, but what if you solve the puzzle with clever overlaps and create extremely realistic models?
Who dares to try this and has examples? Or have we simply become too accustomed to the standard approach?
