ᐅ Which Ikea Pax wardrobe doors are especially resistant to scratches?
Created on: 8 Feb 2024 14:23
Letarkan
Letarkan
8 Feb 2024 14:23
Hello everyone, I am currently looking for an Ikea PAX wardrobe system and am researching the different door designs, especially regarding their scratch resistance. The door fronts vary depending on the model and finish, and since I plan to use my furniture for a long time, it is important for me to choose a surface that is as durable and resistant as possible to avoid scratches and minor damage.
I am therefore interested in which PAX wardrobe doors you consider to be particularly resistant to scratches based on your experience. Specifically, are there models or finishes that have proven reliable in everyday use, for example in households with children or pets? How do lacquered doors compare to doors with foil finishes or glass?
Do you have any care tips, or are there surfaces that, despite appearing robust, are actually very prone to damage? I look forward to detailed reports and nuanced opinions. Thank you!
kasan
8 Feb 2024 15:38
Interesting question!
You mentioned “choosing a surface that is as robust and durable as possible to best prevent scratches and minor damage.” However, I would differentiate here between the actual material properties and the surface technology or finishing process. For Ikea PAX, there are doors made of MDF with various surfaces, such as melamine coatings, painted fronts, or glass.
A common missing detail in many user reports is how severe and what types of scratches are meant. Fine surface scratches from everyday contact are one thing, deep scratches or chipped areas another.
In my experience, and based on tests of furniture surfaces in general, foil laminates on MDF are often quite resistant to scratches from daily use. Painted doors usually have a more refined appearance, but with lower-quality paint, scratches can quickly become visible—and repairs can be difficult. Glass is generally hard and scratch-resistant, but of course not indestructible—however, glass does not show white scratches like wood or foil surfaces do.
It would also be important to consider how often and for what purposes the cabinet doors will be used. If I may be a bit critical: why not also consider protecting against scratches through targeted measures (for example, using appliances or items that don’t have sharp edges which might contact the doors)?
What exactly do you mean by “robust” in your case? Are you concerned about everyday wear and tear or more intense stresses?
GALEO4
9 Feb 2024 10:05
kasan schrieb:
Why not also consider preventing scratches through targeted protective measures (for example, using devices that do not bring sharp-edged objects into contact with the doors)?
I completely agree – the idea of finding an absolutely scratch-free surface is, in my opinion, unrealistic. Everyday items inevitably show signs of use, whether we like it or not.
But to address Letarkan’s original question: I would even argue that for Ikea PAX, the options with foil-coated MDF surfaces offer the best combination of price, ease of care, and scratch resistance. The “painted” doors, such as box-style smooth painted ones, look elegant but any scratch is immediately visible, even though they are supposedly scratch-resistant.
One more slightly provocative thought: If you really want the piece of furniture to stay perfect for a long time, why not consider completely different systems? PAX is not exactly the pinnacle of furniture surface technology. But if you still want to stick with PAX, I recommend foil doors or glass because of their lower visibility of damage.
As a final tip: Fingerprints and micro-scratches quickly become embedded in high-gloss paint finishes – so better avoid high-gloss fronts, especially with heavy use.
SUBEN60
9 Feb 2024 21:47
As someone experienced with furniture materials and their properties:
For truly scratch-resistant doors in IKEA PAX systems, I recommend doors with a melamine resin coating. These are significantly more durable than painted or foil-covered doors. Melamine is hard and resists scratches better, and the surface is also resistant to water and many chemicals.
GALEO4 schrieb:
Fingerprints and micro-scratches quickly embed themselves into high-gloss lacquer surfaces – so it’s best to avoid high-gloss fronts, especially with heavy use.
That sums it up perfectly. High-gloss finishes are often underestimated, particularly regarding maintenance. If you want the most durable surface, matte with a melamine coating is the best option. Glass is scratch-resistant but has drawbacks in handling and weight.
Additionally, when installing and using the doors, be careful not to press sharp-edged objects against the surface, as it remains vulnerable despite its hardness.
One more tip: some foils look nice but tend to peel or get damaged more quickly under heavy use.
I’m happy to provide more details if needed.
