ᐅ Which Ikea Pax wardrobe configurations are suitable for small spaces?
Created on: 4 Nov 2021 08:37
berndmauHello everyone, I am currently focusing on storage solutions for very small living spaces and came across the Ikea PAX wardrobe systems. I am particularly interested in which PAX wardrobe combinations work best for small rooms without appearing too bulky or taking up too much space. It is important to me to find a balance between maximum storage capacity and the most compact footprint possible. What should be especially considered when putting together the modules in small rooms? Are there specific widths, depths, or heights that are more suitable? I would also like ideas on doors (sliding or hinged) and interior layouts. I appreciate practical tips and shared experiences!
Hi berndmau, great topic! 😄 I think for small rooms, PAX wardrobes with sliding doors are a real advantage – they save space because there are no hinged doors getting in the way when opened. I chose a combination of 50cm (20 inches) width and 40cm (16 inches) depth, which fits perfectly in small rooms without looking too bulky. It’s important to plan the interior layout smartly – for example, using plenty of shelves and drawers so you can fully utilize the space without it feeling cluttered. In my experience, it’s better to have several small, slim units rather than one large, wide wardrobe. This keeps the room feeling more open. And by the way: a light-colored carcass and doors make the room appear even bigger. Good luck with your planning!
Regarding berndmau’s question about suitable Ikea PAX wardrobe combinations for small rooms, I can provide the following precise advice: - The base modules are available in standard widths of 50 cm (20 inches) or 75 cm (30 inches), with 50 cm (20 inches) being the better choice for tight spaces. - A depth of 35 cm (14 inches) is generally sufficient for clothing and significantly reduces the space required compared to the standard 58 cm (23 inches) depth. - Heights of 201 cm (79 inches) save space compared to the 236 cm (93 inches) versions because a lower piece of furniture appears less visually dominant, and the ceiling height in smaller rooms is often limited. - Sliding doors offer the advantage of not needing extra clearance in front of the wardrobe to open, which is crucial in small rooms. - The interior setup should be functionally organized, for example, hanging rods positioned close together, drawer inserts, and well-utilized shelves. In summary, I recommend a combination of narrow, shallow, and low PAX units with sliding doors.
Hello berndmau, to find the right PAX combination for small rooms, a systematic approach is best. First of all, accurate room measurements are crucial: record width, depth, and ceiling height precisely – also consider any angles and recesses. For the PAX system in small spaces, I would recommend the following: - Width: 50 cm (20 inches) modules, as these are easier to adapt and create fewer space blockages. Several smaller modules side by side appear more open than one large wardrobe. - Depth: For minimal space usage, the reduced depth of 35 cm (14 inches) is advisable instead of the usual 58 cm (23 inches). This keeps enough room for movement. - Height: 201 cm (79 inches) is often sufficient, mainly for better reachability and because it doesn’t feel as bulky in the room. - Doors: Sliding doors don’t require additional clearance when opened, which is important in small rooms. They are more expensive but worth the extra space saved. - Interior fittings: I recommend a combination of adjustable shelving systems, drawers (for smaller items), and a hanging rail that can be adjusted for different clothing lengths. Possible pitfalls: Pay attention to the positions of windows, radiators, and power outlets to avoid impractical wardrobe placement. Also keep in mind that sliding doors are relatively heavy, so proper installation is important. Can you provide more details about the exact room? Dimensions, usage, existing furniture?
I would like to add the following regarding the usability of PAX wardrobes in small spaces: It is important not only to consider the dimensions but also the access to the wardrobe. Sliding doors save space, but if the wardrobe becomes too long, reaching inside can quickly become difficult. Sometimes it helps to divide the wardrobe into separate sections that can be opened individually instead of just one large unit. This has worked very well for me, as I don’t have to search through everything all the time, making it more organized. Additionally, it visually lightens the room when, instead of one bulky wardrobe, you line up several slim units with some space between them. Maybe this can help with your planning.
