ᐅ What are the standard available sizes for Ikea Metod kitchen cabinets?
Created on: 9 Jan 2023 13:42
MartheHello everyone,
I am currently planning a new kitchen and am particularly interested in the IKEA Metod cabinets. To create an accurate layout, I would like to know what standard cabinet sizes are available in the Metod range.
I am especially interested in the widths, heights, and depths that IKEA currently offers for the Metod base cabinets, wall cabinets, and tall cabinets. Are there fixed standard sizes or more flexible options?
If anyone can share their experience: which sizes are most common and easiest to combine? Additionally, it would be helpful to know if IKEA has updated these dimensions recently or if they have remained the same for years.
I would appreciate a detailed list or overview as much as possible.
By default, IKEA offers the Metod cabinets in the following widths: 20 cm (8 inches), 40 cm (16 inches), 60 cm (24 inches), 80 cm (31 inches), and 100 cm (39 inches). The height varies depending on the cabinet type, ranging from approximately 80 cm (31 inches) for base cabinets up to 220 cm (87 inches) for tall cabinets. The depth is usually 60 cm (24 inches) for both base and tall cabinets, while wall cabinets are shallower, typically 37 cm (15 inches). These dimensions are the most common in the range.
Hello Marthe,
I’d like to provide a more detailed response, as the topic is quite complex. The IKEA Metod series is designed to be modular, giving you some flexibility in assembling it; however, there are clear standard sizes based on the most popular kitchen dimensions.
Base cabinets are available in widths increasing in 20 cm (8 inches) increments from 20 cm (8 inches) up to 100 cm (39 inches). The standard height is about 80 cm (31.5 inches) without the countertop, which brings the total height with countertop and legs to around 90–91 cm (35–36 inches). Different interior heights are available thanks to adjustable inserts.
Wall cabinets typically come in heights of 40, 60, or 80 cm (16, 24, or 31 inches), widths from 20 to 80 cm (8 to 31 inches), and a depth of 37 cm (15 inches). Tall cabinets are usually 200 or 220 cm (79 or 87 inches) high and 60 or 80 cm (24 or 31 inches) wide.
The standard depth for base and tall cabinets is 60 cm (24 inches), which is common for kitchens; wall cabinets are shallower.
IKEA has kept these dimensions consistent over the years, which simplifies replacement but also imposes certain limitations. It’s best to check the IKEA planning tool to see the currently available sizes.
If you want more details, for example about interior layouts, just let me know.
I am happy to add an overview with typical standard sizes and a few tips:
- Base cabinets: Standard heights around 80 cm (31.5 inches), widths: 20, 40, 60, 80, 100 cm (8, 16, 24, 31.5, 39.5 inches), depth usually 60 cm (24 inches).
- Wall cabinets: Heights 40, 60, 80 cm (16, 24, 31.5 inches); widths from 20 to 80 cm (8 to 31.5 inches); depth usually 37 cm (14.5 inches).
- Tall cabinets: Heights 200 or 220 cm (79 or 87 inches); widths 40, 60, 80 cm (16, 24, 31.5 inches); depth 60 cm (24 inches).
Important for planning:
- Account for the countertop thickness, usually between 2.8 and 3.8 cm (1.1 to 1.5 inches).
- Feet adjust the height of the base cabinets, which is important for ergonomic kitchen work.
- Sometimes there are special sizes available (e.g., 15 cm (6 inches) narrow cabinets for gaps), but these are more of a supplement.
A common planning error is mixing up the interior measurements or assuming the front width equals the cabinet carcass width, as the front is usually slightly larger.
Tip: If possible, stick to standard sizes, as this makes replacement easier and saves costs.
Genevieve10 Jan 2023 10:57Interesting discussion so far. However, I would like to question how binding the mentioned standard dimensions really are. IKEA itself describes the METOD series as modular and customizable.
Is it not the case that IKEA makes smaller adjustments depending on the country or season?
Additionally, it is often said that despite standard dimensions, people frequently face unique room situations that require more individualized solutions – this is where METOD reaches its limits.
Could someone share their experience regarding how standardized the "standard sizes" really are and to what extent IKEA offers exceptions or special sizes? In my own research, I have found somewhat contradictory information on this.
For clarification: IKEA Metod cabinets follow a clearly defined size grid that is largely consistent internationally.
Standard overview:
- Widths: 20 cm, 40 cm, 60 cm, 80 cm, 100 cm wide
- Heights:
- Base cabinets: 80 cm (without countertop)
- Tall cabinets: 200 cm and 220 cm
- Wall cabinets: 40 cm, 60 cm, 80 cm
- Depths:
- Base and tall cabinets: 60 cm
- Wall cabinets: 37 cm
These dimensions have remained largely unchanged since Metod was introduced in 2014. Special sizes (e.g., 15 cm wide cabinets) are mainly offered to fill gaps but are not part of the standard core range.
The reliability of these dimensions makes planning, installation, and replacement easier.
There are hardly any regional variations; differences are usually limited to fronts or handle options. The modular design also allows for flexible internal layouts, providing room for customization.
Standard overview:
- Heights:
- Depths:
