ᐅ Which DIY projects are especially well suited for Ikea Hemnes?
Created on: 12 Feb 2022 09:37
Nar51
Nar51
12 Feb 2022 09:37
I am currently exploring which DIY projects work particularly well with the Ikea Hemnes furniture series. Since Hemnes includes a wide range of classic wooden furniture with a fairly traditional design, I am especially interested in the types of custom builds, enhancements, or modifications that best complement this furniture line. Specifically, I want to know which DIY projects not only fit Hemnes aesthetically but are also functionally useful—whether for living rooms, bedrooms, or even entryways. I’m interested in both more complex woodworking projects as well as simple upcycling ideas that can be done with manageable effort. I look forward to tips, detailed instructions, or personal experiences that can help unlock the potential of Hemnes for custom interior solutions.
derrick34
12 Feb 2022 10:04
Paint and stain projects are ideal for giving Hemnes furniture an individual look. A simple idea is to paint the furniture with chalk paint and then skillfully sand the edges to create a shabby chic effect. Changing the handles also makes a big difference, as it allows the style to be updated quickly. For the hallway, homemade storage systems that clip onto Hemnes shelves are practical.
Ethan
12 Feb 2022 15:22
Hello Nar51,
your topic is very well chosen, as Hemnes, with its timeless solid wood construction, is excellent for DIY projects. Here are some suggestions with explanations:
- Shelves and expansions: Hemnes shelves have standardized dimensions, making it easy to add extra shelves or small wall cabinets. Those with some carpentry skills can build custom inserts to increase storage space.
- Surface treatment: In addition to traditional painting, you can experiment with wood oil or wax to protect the surface or give it a special tone. This way, the wood grain remains visible.
- Replacing door and drawer handles: New handles or knobs made of metal or leather add modern accents and make Hemnes furniture appear less typical of Ikea.
- Functional upgrades through upcycling: For example, a dresser can be converted into a bar or desk with a simple additional insert. Custom designs for cable management inserts are also popular.
These modifications require different skill levels; if you like, I can also recommend step-by-step instructions.
I hope this provides a good overview!
Nofege
13 Feb 2022 08:47
Ethan schrieb:
These adjustments require different levels of craftsmanship. If anyone is interested, I can also recommend step-by-step guides.
I would like to pick up on that and clarify: For especially successful DIY projects with Hemnes furniture, I recommend following these steps:
- Planning: Measure your piece of furniture precisely and consider what purpose the DIY project should serve (e.g., more storage, decorative accents, improved ergonomics).
- Material selection: Use materials that complement the dark or white wood of Hemnes furniture (solid wood strips, metal fittings, leather).
- Surface modification: A common mistake is insufficient surface preparation, such as not completely removing old paint residues or wax. After that, use masking tape and work with fine sandpaper.
- Construction: Pay attention to screw lengths and drilling positions to ensure the furniture remains stable. Use appropriate dowels and glue as needed.
- Finishing: Oils, stains, or varnishes should be applied in several thin layers to achieve an even result.
- Final assembly and function test: After putting everything together, be sure to check the stability.
One example project that works well: a pull-out drawer compartment installed in a Hemnes dresser to neatly store tech accessories or cables.
I’m happy to help if anyone needs a more detailed guide for a project, especially regarding assembly safety and material choice.
