ᐅ Which colors work well with IKEA Besta units in a Scandinavian interior design style?
Created on: 12 Nov 2016 14:23
furaso
furaso
12 Nov 2016 14:23
I have a rather specific question related to setting up a Scandinavian-inspired living room. I plan to use the IKEA Besta system as a central piece of furniture because its simple design and flexibility suit my needs perfectly. However, I find it challenging to choose color schemes that integrate these units harmoniously without compromising the Scandinavian style.
Specifically, which colors work well with IKEA Besta in a Scandinavian living style, especially if you prioritize naturalness, brightness, and a cozy atmosphere? Are there any color tips or combinations you would recommend to keep the overall look balanced and modern without making it feel too cold or sterile?
I look forward to your practical suggestions, including which accent colors are particularly effective in bringing the space to life. Tips on wall colors, textiles, or accessories are also very welcome.
Thanks in advance!
harold
12 Nov 2016 16:07
Hello furaso,
your question about harmonious color combinations with the IKEA Besta in Scandinavian interior style can be approached quite systematically. Scandinavian style is mainly characterized by clear, light tones, natural materials, and simple shapes. IKEA Besta, with its white or wood-colored fronts, provides a good foundation for this.
A brief mini-tutorial for you:
- Base colors: White, off-white, or very light gray are ideal for maintaining freshness and lightness. These should be chosen for walls and larger surfaces.
- Natural colors: Warm wood tones are a typical element that also go well with Besta. They add warmth to the room and pleasantly break up the brightness.
- Accent colors: Typical for Scandinavian interiors are pastel shades such as light blue, sage green, soft pink, or a subtle mustard yellow. You can introduce these colors through cushions, throws, vases, or small shelf inserts.
- Contrast colors: Darker gray or anthracite tones can add some depth – for example, as a rug or lampshade.
Common mistakes include using too many bright colors or overly dark tones, which can disturb the airy atmosphere. Also, too many patterns can disrupt the simple look.
In short: Stick to light walls, add warm wood tones as a complement, and sprinkle in pastel accents – this keeps it typically Scandinavian and modern.
If you like, I can also write up a sample color plan for you.
bareynaldo
13 Nov 2016 09:51
harold schrieb:
Accent colors: Typical for Scandinavian interiors are pastel shades like light blue, sage green, soft pink, or a gentle mustard yellow.
I want to raise a somewhat controversial point here: If every Scandinavian home style is automatically associated with pastels and soft tones, it simply becomes boring over time. Sure, that’s the mainstream look, but why not try colors with more energy?
Why shy away from bold accent colors like a deep navy blue or even a warm terracotta? Especially paired with white or light Besta, it looks fantastic and avoids the “sterile clinic look” that some people fear with pastels. My view is that Scandinavian style doesn’t always have to be pastel and safe—there’s room for passion without betraying the core concept.
That doesn’t mean you should mix colors wildly. Thoughtful and brave use of color is what makes it exciting. Besta can definitely handle strong contrasts when applied carefully.
Maybe it’s worth considering: instead of sticking to one color family, you could deliberately add striking color accents to express personality.
Lance
14 Nov 2016 21:34
Hello furaso and everyone following this,
I would like to address the question more technically and precisely: Which colors work well with IKEA Besta in the Scandinavian interior style – especially considering lighting conditions, material properties, and their impact on the space.
First of all, it’s important to note that Besta is not only available in pure white but also in other front colors, such as wood finishes ranging from oak to walnut. The color of the furniture significantly influences how the surrounding colors are perceived.
If you are using a white or very light version, the following factors come into play:
- Light management: With limited natural light, it is better to choose warm base colors or slightly warmer whites (cream, ivory) for the walls to improve the atmosphere.
- Wall colors: Besides pure whites, light gray tones with warm undertones work very well – for example, a light dove gray. This lets the white of the Besta stand out without appearing cold.
- Accents: I recommend introducing your accents through textiles and smaller furniture pieces, such as a rug or side table. Muted natural colors like olive green, light mustard yellow, or terracotta work very well.
If you lean towards a wood-colored Besta front, then:
- Wall colors should be in rather neutral to warm shades – avoid cool blues, as they tend to clash.
- Accents can be earthier and stronger: aubergine, dark teal, deep brick red.
In summary: A harmonious color scheme relies on a balanced mix of neutral to warm base colors plus selective accents coordinated with the furniture. I suggest first determining exactly which Besta variant is being used and what the lighting conditions in the room are – this guides a more specific color choice.
Maybe you could share a bit about your room? Size, natural light, Besta model?
