ᐅ Which maintenance products are suitable for the surface of BILLY shelves?
Created on: 22 Jul 2022 08:17
Minkeo
Minkeo
22 Jul 2022 08:17
I recently bought several Billy shelves from IKEA and want to maintain them so that the surfaces stay in good condition for as long as possible. The shelves are made of coated particleboard, usually with a melamine or lacquer finish, and I am wondering which cleaning and care products are best suited for these surfaces.
In particular, I am interested in:
- Which cleaning agents are suitable without damaging the surface?
- Are there any special care products that help preserve the shine or protect the material?
- What should definitely be avoided to prevent damage such as scratches, discoloration, or peeling of the coating?
I would appreciate any recommendations and personal experiences on this topic!
Paunon
22 Jul 2022 09:03
For cleaning BILLY shelves, I recommend using a soft, damp cloth and mild soap. Do not use harsh cleaners or abrasive agents. Wipe dry afterward. For maintenance products: wax-based furniture polish is acceptable, but use sparingly.
funon5
22 Jul 2022 09:47
Hello Minkeo,
Your question is very important because improper care can quickly damage the surface of BILLY shelves. Most BILLY shelves are coated with melamine resin, which is fairly durable but not indestructible.
For cleaning, I recommend:
- Use a lint-free, soft cloth that is only lightly dampened.
- Use mild cleaning agents such as heavily diluted dish soap.
- Avoid abrasive cleaners and harsh chemicals like ammonia or alcohol.
For maintenance:
- You can use special furniture care products designed for melamine surfaces, but always test them first on an inconspicuous spot.
- Alternatively, silicone-based products can be used to help maintain shine and protection.
What to avoid:
- Soaking the shelves with water.
- Harsh or abrasive cleaning products.
- Heat and direct sunlight, which can increase discoloration.
If you use the shelf in the kitchen, it is especially important to remove greasy or sticky residues quickly.
I hope this helps!
naujon
22 Jul 2022 10:15
I would like to add a brief care tutorial, which is particularly useful for BILLY shelves:
1. Cleaning:
- Use lukewarm water with a few drops of mild dish soap.
- Lightly dampen a microfiber cloth and gently wipe the surface.
- For stubborn stains, wipe gently multiple times rather than applying strong pressure.
2. Drying:
- It is important to thoroughly dry the surface afterwards with a dry cloth to prevent water marks or moisture damage.
3. Care:
- You can use furniture polish designed for laminate or melamine very sparingly. This helps prevent drying out and maintains the shine.
- Avoid oils or waxes, as they can leave greasy residues.
4. Common mistakes:
- Avoid aggressive cleaners (e.g., harsh cleaning agents, bleach) as they can damage the surface.
- Do not soak the surface directly, since chipboard can swell.
Summary: Mild cleaning agents, soft cloths, and gentle care products are the right way to maintain BILLY shelves optimally.
SETHBLA
22 Jul 2022 11:58
I would like to add the following two tips:
1. Avoid microfiber cloths with a soft pile, as they can sometimes cause fine scratches. It's better to use very smooth variants.
2. Ideally, avoid polishes with a high oil content, as they often make the surface sticky and attract dust.
For simple cleaning, mild soap solutions are completely sufficient.
Landontau
23 Jul 2022 08:34
Exactly, here is a brief explanation regarding the surface: Melamine resin provides the shelves with a scratch- and impact-resistant finish. However, mechanical stress such as sandpaper or harsh abrasive cleaners are the weak point, as they can damage the protective layer.
For cleaning, I recommend the following approach:
- Use pH-neutral cleaning agents.
- Wipe with a soft, damp cloth, not wet.
- For grease stains, a diluted solution of denatured alcohol and water (1:10) is suitable, but test it first in an inconspicuous area.
For maintenance:
- A mild furniture care product, especially designed for laminate or melamine, helps to extend the surface’s lifespan.
- Make sure the care product does not leave any residue.
Most importantly: Avoid standing moisture and direct heat exposure, as both can damage edges and joints.
