ᐅ Which versions of Billy are best at resisting moisture?
Created on: 20 Feb 2021 10:12
REPIRU
REPIRU
20 Feb 2021 10:12
I am currently looking into the question, "Which Billy variants are best at resisting moisture?" and I am searching for specific experience-based insights and distinctions between the different versions and materials.
I am particularly interested in how the classic Billy shelves made from particleboard or MDF perform in more humid environments, such as bathrooms or areas of the house with higher humidity.
Are there differences between variants, for example, coated surfaces or other materials that are better suited?
I am also interested in information regarding durability and maintenance, as well as preventive measures against swelling, mold, or warping.
Looking forward to well-informed answers and experience reports!
dijan
20 Feb 2021 10:45
Hey REPIRU,
great question, because moisture and Billy shelves are quite the combination – like fire and ice, you could say 😊.
Most Billy shelves are made from particleboard with a thin melamine coating, which can handle normal humidity but tends to swell quickly with constant moisture.
My recommendation: if it’s a bit more humid, definitely go for the "Billy bookcase with doors" version. These are a bit more durable because the doors and back panels are fitted more tightly.
Additionally, you can treat the shelves with special clear varnishes or waterproofing agents. This significantly extends their lifespan against moisture.
Of course, this isn’t 100% protection, but it’s better than nothing 🙂
naujon
20 Feb 2021 12:03
regarding moisture resistance of Billy shelves, here is a brief overview:
1. Material: Standard Billy shelves are usually made of particleboard/chipboard with a melamine foil surface. These are not water-resistant; moisture causes swelling.
2. Variants: There are models with foil-coated surfaces that are somewhat more moisture-resistant but cannot withstand being submerged in water.
3. Alternative: The Billy version made from MDF is denser and absorbs less moisture than particleboard, making it somewhat better suited.
4. Additional protection: Using water-resistant coatings (e.g., clear varnish) and avoiding direct contact with water.
Common mistakes:
- Placing shelves directly against damp walls
- Putting wet clothes or items on the shelves
In short: Standard Billy models are not designed for permanently damp environments; it is better to opt for special moisture-resistant furniture made of plastic or metal.
Katau
20 Feb 2021 13:37
Hello REPIRU,
Basically, I can only confirm that the classic design of the Billy shelves is intended mainly for dry to moderately humid indoor spaces. The particleboard material absorbs moisture and tends to warp or swell as a result.
dijan schrieb:
Most Billy shelves are made of particleboard with a thin melamine coating that can withstand normal humidity but will swell quite quickly under constant moisture.
In my experience, that description is quite accurate. It is also important how the back panel is installed: it is usually made of very thin cardboard, which easily becomes soggy when exposed to moisture and reduces the overall stability.
If you still want to use the shelf in a bathroom or other humid area, I recommend placing it slightly away from the wall to allow ventilation behind it. Additionally, applying a coat of water-repellent paint or varnish can improve durability.
Unfortunately, IKEA does not offer a special Billy version with moisture protection. Some users opt for the version with doors, as it closes better and therefore helps keep moisture out to some extent.
My final advice: if possible, consider alternatives made of metal or plastic. Wood-based materials are generally problematic in bathrooms where steam and occasional splashes occur.
enrique7
20 Feb 2021 15:22
I would like to make a critical comment at this point:
Many reviews regarding the moisture resistance of Billy models are based on subjective experience without precise information about the source of moisture or the surrounding climate.
naujon schrieb:
Standard Billy usually consists of particleboard with melamine foil. These are not water-resistant; moisture leads to swelling.
This is technically correct, but the key factor is the moisture in the air (relative humidity) versus direct water contact.
Therefore, anyone who thinks Billy shelves will not hold up in a normal, well-ventilated bathroom should check if they are controlling the air humidity or if there are issues due to poor ventilation.
Up to 60% relative humidity is tolerable for typical Billy particleboard conditions; above 80%, it becomes problematic.
Conclusion: The model and surface finish are secondary; the environment and maintenance are more important—for example, regular ventilation prevents mold and swelling. Hence, a recommendation for a "better" Billy would be more about water-repellent treatment or proper placement rather than different versions themselves.
FEKAU
20 Feb 2021 16:40
Summary of Key Facts Regarding Moisture and Billy Shelves:
1. Material: Standard Billy shelves are made of melamine-coated particleboard, which can swell when exposed to moisture. MDF versions show slightly better resistance to moisture.
2. Surfaces: The melamine coating protects against surface moisture, but not against prolonged exposure to water or high humidity.
3. Construction Measures: Maintaining a gap from the wall, ensuring good ventilation, and avoiding direct contact with water significantly increase durability.
4. Alternative Furniture: Coated metal shelves or plastic furniture are recommended for damp rooms.
5. Care: Regularly drying surfaces and temporarily avoiding moisture sources helps maintain condition.
6. Experience: Applying a water-repellent varnish or impregnation is an option for Billy shelves to make surfaces somewhat more resistant to moisture.
These points are based on the material properties according to manufacturer specifications and practical experience. There is no official moisture-resistant "Billy version."
