ᐅ Which Billy bookcases can support the most weight?
Created on: 20 Apr 2024 13:27
Ki-keo
Ki-keo
20 Apr 2024 13:27
Hello everyone, I am currently looking into which Billy shelves can support the most weight, as I plan to store heavy books and binders in them. I understand that the load capacity usually depends on the shelf size, material thickness, number of shelves, and wall mounting. However, I am particularly interested in whether there are different versions of Billy shelves regarding load capacity and if the stability can be significantly improved by additional measures. Are there reliable specifications or experience reports from the forum? Which version of the Billy shelves is recommended for a maximum uniform load per shelf, and how does this relate to the overall construction? Thanks in advance for your insights!
Lucien
20 Apr 2024 14:01
The maximum load capacity of a single shelf in a standard Billy bookcase (80cm by 28cm (31.5 inches by 11 inches) footprint) is approximately 30 kg (66 lbs), according to the manufacturer, assuming the load is evenly distributed and the unit is properly assembled.
It is important to secure the bookcases to the wall to prevent tipping and to ensure additional stability. Variants such as the larger Billy XL models or higher-end versions with reinforced shelves can sometimes support loads of up to 50 kg (110 lbs) per shelf.
Additionally, load capacity can be increased by using metal shelf brackets or wooden reinforcements beneath the shelves. For particularly heavy loads, distributing the weight across multiple shelves or installing additional vertical dividers is recommended.
For long-term loads, the humidity conditions and the age of the bookcase should also be considered, as damp or aged wood tends to weaken more quickly.
U
usbla
20 Apr 2024 14:53
Lucien schrieb:
It is important that the shelves are mounted to the wall
This is a crucial point. Without wall mounting, the load capacity is significantly reduced, especially for taller units.
Additionally, Ikea states that using the shelves as freestanding units lowers the maximum load to 15-20 kg (33-44 lbs) per shelf.
Another way to increase load capacity is by using “Billy shelf reinforcements” or adding a support beam underneath a wider shelf. These help minimize sagging.
Interestingly, the thickness of the shelves (typically around 1.8 cm (0.7 inches)) also plays a role. Some users report that shelves become noticeably more stable when reinforced with special hardwood strips.
KNUTGI
20 Apr 2024 16:12
Hello 🙂 I loaded my Billy bookshelf with heavy university textbooks—each shelf held several kilograms (a few dozen pounds).
What I can say is that the standard shelves are fine as long as you don’t load them with weights comparable to a small jackhammer. My biggest issue was that the shelves sagged a bit over time without any extra support.
Since I screwed some additional wooden slats underneath the shelves, the bookshelf has become much more stable, and I can easily load about 40 kilograms (90 pounds) per shelf without any signs of strain.
I also definitely recommend using the wall bracket. Without attaching it to the wall, the whole thing becomes quite wobbly, especially if, like me, you often rush around and toss things into the shelf backwards 😉
BARSAN
20 Apr 2024 17:28
Standard Billy shelf: max 30 kg (66 lbs). Wall mounting required. For higher loads: use shelf reinforcement or additional battens. Billy XL supports more weight, up to approx. 50 kg (110 lbs) per shelf.
Jensson
21 Apr 2024 08:17
A brief guide to effectively increase the load capacity of your Billy shelf:
1. Make sure all IKEA fittings are correctly and securely installed – loose connections reduce load capacity.
2. Mount the shelf to the wall using the included fixings. Without wall mounting, 30 kg (66 lbs) per shelf is unrealistic.
3. For wider shelves (e.g., 80 cm (31.5 inches)), bending can become an issue. A center support made of wood or metal under the shelf helps distribute the weight evenly.
4. Use shelf supports available as accessories, or reinforce with appropriate battens. These prevent long-term sagging.
5. Distribute heavy loads across several shelves instead of placing a lot of weight on a single one.
Common mistakes are neglecting the wall mounting and overloading individual shelves. By following these points, you can achieve or even exceed the load capacity specified by the manufacturer.
