ᐅ Which BILLY shelving units are ideal for the home office?
Created on: 22 Feb 2020 08:13
kodan
Hello everyone, I am considering which IKEA Billy bookcase would be best suited for an office. My focus is on functionality, storage capacity, and stability, as I want to store both file folders and some decorative items. It would be great if it were also flexible and adjustable, as space is somewhat limited and I occasionally like to rearrange. Does anyone here know the different versions of the BILLY bookcase and can share from experience which works particularly well in an office? Any information on dimensions, load capacity, and assembly would also be appreciated!
kodan
22 Feb 2020 11:42
Thanks for the initial tips! The points about wall anchoring and load capacity are very helpful for me.
liste schrieb:
Maximum load per shelf is also crucial
Can someone provide exact values for this? I mainly want to store files with wide and heavy binders. I’m also interested in how adjustable the shelves are in the larger units. Additionally, I’d like to know if the shelves can be combined in any way to, for example, fit a corner in an L-shape.
SINEL
22 Feb 2020 12:08
The shelves of the Billy unit can support approximately 15 kg (33 lbs) when the load is evenly distributed. Combining the shelves into L-shaped configurations is possible through screw connections on the sides, but this is not officially supported by IKEA. For stable corners, it is better to use corner shelves or a combination of BILLY and other systems.
Marion
22 Feb 2020 14:25
For your application, shelves with a height of 202 cm (79 inches) and a width of 80 cm (31.5 inches) are better. They provide plenty of storage space and are designed for files. Important: use additional back panels and wall mounting for stability.
Wesley
22 Feb 2020 15:37
If you want to use BILLY smartly in the office, it’s worth experimenting with a few extras – like LED light strips or small boxes as organizers. It improves visibility and instantly makes the workspace feel cozier. 🙂
My tip: Use the larger 80x28x202 cm (31½x11x79½ inches) model for the main storage and slimmer versions for additions. This way, you can quickly store cards, folders, or decorations scattered around.
LIELCHEN
22 Feb 2020 16:50
I don’t see it quite so lightly!
kodan schrieb:
whether the shelves can be combined somehow to, for example, outfit a corner in an L-shape
That sounds more like a lazy compromise. If you want to set up an office properly, you shouldn’t cobble together BILLY corners—there are better solutions! BILLY is not a professional office system but an all-rounder.
So if you need optimal storage space and frequently work with files, it’s better to look into professional shelving systems like those from Hettich, USM, or industrial storage solutions. BILLY is only ideal if you prioritize design and flexibility, not just load capacity.
fepau
22 Feb 2020 18:02
LIELCHEN schrieb:
BILLY is only perfect if you focus on design and flexibility, not just load capacity.
I somewhat agree! Of course, if you need to store heavy loads, typical storage cabinets are a better choice. But for small to medium offices, especially home offices, BILLY is a real all-rounder! Personally, I think the combination of storage space, price, and easy adaptability is hard to beat. 🙂
