ᐅ Which Billy bookcases are best suited for heavy books and files?
Created on: 6 May 2019 14:23
kenlewinHello everyone,
I am currently reorganizing our small office, and we want to finally store our heavy books and files properly. I am considering the Billy shelving units from Ikea because they are affordable and space-saving. However, there are different versions and add-ons, and I have no idea which model is best suited to support the weight of heavy books and files.
So my detailed question is: Which Billy shelving units are particularly suitable for safely and permanently storing very heavy books and files? I am especially interested in the load capacity of the shelves, possible reinforcements, optimal depth or width, and whether there are specific accessories that can be used for additional stability.
If anyone has practical experience, recommendations, or technical data, I would be very grateful.
Thanks in advance!
Thanks in advance!
Hello kenlewin,
I have been using Billy shelves myself for a while now to hold heavy books and have a few helpful tips on how to make the shelves stable for heavy loads:
1. Choose the Billy version with an 80 cm (31.5 inch) width if possible, rather than the narrower ones (40 cm / 15.7 inch), as wider shelves tend to sag less.
2. Make sure the shelves are made from sturdy particleboard; the original supports about 15–30 kg (33–66 lbs) per shelf when the weight is evenly distributed. If you have very heavy books, reinforcing the shelves with additional supports or metal brackets underneath can be worthwhile.
3. Using back panels is especially helpful because they stabilize the structure and prevent tipping. You can also add a second back panel sheet for extra reinforcement.
4. Securing the shelf to the wall prevents tipping and makes the entire construction safer.
5. Billy shelves with an extra center support (often available in the wider versions) provide increased stability.
In summary: For heavy books, a wider Billy shelf is worth it, preferably fixed to the wall and possibly reinforced with metal supports under the shelves. Avoid cheap DIY builds, as they usually cannot hold the load permanently.
If you want more details, I’m happy to help!
Hey, great topic! 🙂 I filled my Billy bookshelf with heavy encyclopedias – at first, I was worried, but with the 80cm (31.5 inches) version and wall mounting, it’s now rock solid.
That’s exactly what I did, and no more sagging!
So: go for the wider Billys, and it will be a nice and stable solution!
maflo schrieb:
Wall mounting and a center support provide more stability.
I think the Billy shelves are overrated when it comes to very heavy loads. Of course, the design is fine for regular books, but for really heavy files or thick reference books, it’s better to choose more robust furniture.
These tips are well intended, but in my opinion, they don't really replace solid, heavy-duty filing cabinets.
My two cents: It’s better to invest in a sturdy office shelving unit; it lasts longer and doesn’t look so shaky.
Kyleli schrieb:
Billy 80 cm (31.5 inches) wide, wall mounting and extra shelf supports if possible
Very good question, kenlewin. I’ll break it down in more detail so you can find the right shelving unit and safely store your heavier books and files.
1. Materials: The common Billy shelves are made of particleboard with a melamine coating, which is affordable but not extremely durable. The individual shelves are about 1.9 cm (0.75 inches) thick, and the load capacity—as maflo correctly pointed out—is roughly 15-30 kg (33-66 lbs), depending on how the weight is distributed.
2. Reinforcements: There are several ways to increase the load-bearing capacity:
- Attach metal shelf supports or additional wooden strips under the shelves
- Use center supports to prevent sagging
- Replace removable intermediate shelves with stronger versions
3. Depth/Size: Larger shelves (80x28 cm (31.5x11 inches) or 80x40 cm (31.5x16 inches)) offer more stability due to the increased surface area. The narrower versions (40 cm (16 inches) wide) are especially prone to sagging under load.
4. Wall Mounting: Absolutely necessary for heavy loads, as Billy shelves can tip over without being secured to a wall.
5. Alternative Products: For extremely heavy files, there are ready-made steel shelving units or office furniture with solid tops that are better suited.
I would recommend first estimating how much weight each shelf needs to hold. For example, if you have several 5 kg (11 lbs) binders or very thick, heavy reference books, I would suggest a combination of a wide Billy unit with additional metal reinforcements. That really makes a difference.
I hope this helps you. Feel free to share the dimensions of your books or the weight classes you expect if you want.
