ᐅ Which BILLY model is best suited for heavy books and binders?
Created on: 3 Sep 2024 14:23
lamevinHello everyone,
I am planning to get an IKEA BILLY bookshelf to securely store mostly very heavy books and numerous ring binders. It is important to me that the bookshelf is sturdy enough to permanently carry the high load and that there is minimal sagging on the shelves.
Which BILLY models would you specifically recommend for this purpose? There are different heights (e.g., 106 cm (42 inches), 202 cm (80 inches)), widths (40 cm (16 inches), 80 cm (31 inches)), and some versions with additional reinforcement or thicker shelves.
Dimensions of the shelf parts and the material or a combination with shelves made of other wood-based materials could also be relevant.
Can anyone provide a reliable recommendation, especially regarding handling heavy loads like ring binders (about 3–4 kg (7–9 lbs) each) and thick reference books? I would appreciate a detailed assessment, including possible alternatives within the BILLY series.
Thank you in advance!
I would choose the BILLY measuring 80x28x202 cm (31½x11x79½ inches), preferably with additional wall anchors between the wall and the shelf. The greater depth provides more stability.
You can reinforce the shelves by placing thin metal strips underneath. The system is not designed for very heavy loads, but this can help improve its strength.
Hello lamevin,
your question is very practical and important. I had a BILLY bookshelf myself, which I used for heavier books and numerous binders. Basically, the standard BILLY with its regular particleboard shelves can sag under higher loads.
What I recommend:
1. Choose the larger model (202 cm height, 80 cm width) – more surface area means more stability.
2. If possible, avoid the standard particleboard shelves and replace them with thicker shelves made of plywood or solid wood, cut to the same width. These are much more durable.
3. Be sure to use wall fixings; this fully stabilizes the bookshelf and prevents tipping or warping.
4. Also consider, besides the classic BILLY bookshelf, a combination with the BILLY/Oxberg system. This offers more adjustability and sturdier shelves.
I hope these tips help you. If you like, I can also provide advice on how to best replace the shelves.
What I recommend:
Ramon4 schrieb:
The classic BILLY with standard wooden shelves can sag under heavier loads.Here are the facts: The BILLY model measuring 80x28x202 cm (31½x11x79½ inches) is the basic sturdy version. However, the standard particleboard shelves are not sufficient to reliably support heavy books or binders over time.
The manufacturer specifies a maximum load of about 15 kg (33 lbs) per shelf – with binders weighing 3-4 kg (6.6-8.8 lbs) each, you will quickly reach the limit.
To increase the load capacity, I recommend:
- Replacing the shelves with plywood panels approximately 18-22 mm (¾-⅞ inch) thick to prevent sagging.
- Adding extra support braces screwed underneath the shelves.
- Securing the bookshelf to the wall with multiple anchors.
Alternatively, IKEA offers supplemental products such as the OXBERG system, which is designed for higher stability requirements.
In conclusion: If you have a large volume of heavy items, I suggest choosing another shelf specifically built for higher loads. BILLY is better suited for moderate weights.
Hello!
I once had a BILLY with heavy loads – it quickly feels like a sagging hammock if you rely only on the standard fittings. 😉
But as already mentioned: the 80 cm (31.5 inches) width with 202 cm (79.5 inches) height is your friend.
If you’re a bit handy, reinforce the shelves with thin metal brackets or long screws for added support.
And don’t forget: when working with construction timber at home, look for plywood or similar – it doesn’t cost much and makes a huge difference.
Finally: fill the shelf evenly and regularly – a balanced load distributes better and keeps the unit sturdy 🙂
