ᐅ Which BILLY shelves are load-bearing?
Created on: 22 Feb 2024 09:17
benreo
benreo
22 Feb 2024 09:17
Good morning everyone,
I am currently looking into choosing BILLY shelves for my home project and have come across an important topic that I would like to discuss with you: Which BILLY shelves from IKEA are actually strong enough to hold heavier loads, such as thick books or large binders?
I am particularly interested in the maximum load capacity per shelf as well as the differences between the various versions (material, size, design). Some say that the basic particleboard versions tend to sag quickly, while others report better load capacities with the more robust models.
Does anyone have experience or reliable technical information on which BILLY models are truly stable? I want to make an informed decision and not choose based on appearance alone.
Thank you for your help!
CHENFAR
22 Feb 2024 09:43
Hello benreo,
In general, the maximum load capacity of a single BILLY shelf is about 30 kg (66 lbs), assuming the unit is properly assembled and the weight is evenly distributed. The classic BILLY bookshelf models are usually made from white melamine-coated particleboard and are designed for average household use.
However, there are versions with reinforced wood back panels and thicker shelves (e.g., with glass or metal reinforcements) that can support heavier loads. IKEA itself specifies around 30 kg (66 lbs) per shelf for the standard BILLY bookshelf.
The shelf height and the number of shelves are also important, as longer shelves are more prone to bending.
If you expect a particularly heavy load, additional support or the use of wall fasteners is recommended, as this significantly increases stability.
pikin
22 Feb 2024 10:12
In addition to what CHENFAR already mentioned: The classic BILLY shelves are specified to support a maximum load of 30 kg (66 lbs) per shelf, according to IKEA.
However, there are also BILLY shelves made from thicker material or with metal reinforcements, which can generally support higher loads, sometimes up to 40 kg (88 lbs).
The installed shelf size is important: The longer the shelf, the greater the bending stress and thus the more it will sag under load.
I also recommend wall mounting – this greatly improves stability and allows for higher loads without tipping.
benreo
22 Feb 2024 10:35
CHENFAR schrieb:
Basically, the maximum load capacity of a single BILLY shelf is about 30 kg (66 lbs)
Thank you, that’s already very helpful! Could you maybe also explain whether models with glass doors or other materials differ in terms of load capacity? For example, I have read that BILLY units with glass doors sometimes have stronger shelves to support the weight of the doors and contents.
And how about versions like BILLY/Oxberg, which seem to have a thinner back panel? Does that affect the overall stability?
TEOZAR
22 Feb 2024 11:01
Good day benreo,
I’m happy to help: The BILLY models with glass doors sometimes have slightly reinforced frame constructions and different shelf designs, which significantly improve stability compared to the standard models.
The thinner back panel on BILLY/OXBERG can indeed reduce stability somewhat, especially for taller shelving units, as it offers less lateral rigidity.
If you plan to store heavy loads, you should definitely use wall mounting and, if possible, consider reinforcing the shelves.
I also recommend not to exceed the maximum load capacity, as this can reduce the lifespan of the shelving unit.
Mufato
22 Feb 2024 11:33
Standard BILLY: Max 30 kg per shelf.
OXBERG is slightly less stable due to a thinner back panel.
BILLY with glass doors is usually more stable.
