ᐅ Which alternatives to BILLY are recommended for common issues?
Created on: 1 Dec 2016 09:07
Nondan
Nondan
1 Dec 2016 09:07
I am currently looking into shelving units and came across the BILLY shelves from IKEA, which are quite popular. However, I keep hearing from several users about various issues such as stability concerns, difficulties with assembly, and some quality-related doubts.
Therefore, I am particularly interested in the question: What alternatives to IKEA’s BILLY shelves are recommended to address these common problems? It would be helpful if you could specifically address the following points:
- Stability and load-bearing capacity
- Ease of assembly
- Price-performance ratio
- Design options and customization
I am not just looking for any shelf, but a well-considered recommendation that realistically counters the typical weaknesses of BILLY.
Thanks in advance for your insights!
Fitigu
1 Dec 2016 10:13
Regarding reliable alternatives to the BILLY shelves, considering their known weaknesses:
A frequently mentioned option is the "Ivar" shelving system from IKEA itself. It offers significantly sturdier wooden components and more flexibility in assembly, as it can be left open and customized. Although it is priced higher, the investment is worthwhile primarily due to its durability.
An alternative outside of IKEA is the "KALLAX" system, which has fewer tall shelves but is very stable and versatile. The modular design can be personalized with various inserts and is generally easier to assemble than BILLY.
Small furniture manufacturers, such as the "String System," offer greater customization and design options but are considerably more expensive and better suited for smaller shelving units.
A practical tip is to always pay attention to materials and fastenings before purchasing to minimize stability issues.
PIN66
1 Dec 2016 12:27
Fitigu schrieb:
A frequently mentioned model is the shelving system "IVAR" from IKEA itself.
I basically agree with that but would like to go a bit deeper into the technical aspects and point out some potential pitfalls: IVAR mainly stands out due to its solid pine boards, which should be treated (painted or oiled) before assembly to prevent warping. This is often a source of error because many people only place the shelves loosely without using appropriate wall brackets.
Stability in alternatives to BILLY is often achieved through wall mounting. Without this, many systems are not truly stable under full load or lateral pressure.
There are also alternatives such as shelving from USM Haller or modular systems from String, which are higher-priced but offer excellent build quality. Technically, problems often arise from a lack of understanding about proper anchoring.
Regarding ease of assembly: KALLAX and IVAR are relatively simple but offer little flexibility for unusual room dimensions. For custom sizes, made-to-measure shelves (including self-built ones) are the best choice, provided you have the time and skills.
In short: If you have issues with BILLY, you should consider the material, wall mounting, and especially the load limits.
Nondan
1 Dec 2016 13:41
Thanks for the tip! That is actually one of the points I wanted to understand better. Are there better or more stable wall mounting systems available with alternatives to BILLY that you would recommend?
Regarding custom solutions: How complex and costly are custom shelving options compared to standard products from furniture stores? I’m asking because I don’t have a carpentry workshop nearby and would prefer not to spend too much time on DIY.
Additionally, it would be interesting to know if there are suppliers in the budget to mid-range shelving segment that offer significantly more robust products than BILLY, without moving into the premium price category.
Laukau5
1 Dec 2016 15:29
Nondan schrieb:
Are there better or more stable wall mounting systems among the alternatives compared to BILLY that you would recommend?
Yes, there are indeed differences. BILLY uses rather simple metal brackets that are functional but not necessarily optimized for additional loads. It is advisable to use so-called heavy-duty wall mounts—such as professional steel brackets, longer wall plugs, and screws with larger diameters. These can also be retrofitted on systems like IVAR or KALLAX.
Nondan schrieb:
How complex and costly are custom shelving solutions compared to the standard products from furniture stores?
The cost factor varies widely. Custom-built units typically start at around 150-200 euros per shelf module, depending on materials and workmanship. If you have less experience with assembly, it’s definitely recommended to include professional advice or installation help, as that can quickly increase the costs.
In practice, modular systems from manufacturers like String or USM are particularly suitable; although more expensive, they offer very high-quality craftsmanship and remain stable over the long term.
Nondan schrieb:
Are there providers in the affordable to mid-range shelving segment who are significantly more robust than BILLY without moving directly into the premium category?
I recommend taking a look at shelving units from XXXLutz or furniture stores offering steel shelving (e.g., “CONFORAMA” or “Roller”)—these tend to be more stable thanks to steel frames and steel shelves, although the design is typically less elaborate.
silako
1 Dec 2016 17:18
I would like to offer a critical perspective here:
The recommendations often mentioned in forums, such as IVAR or KALLAX, are frequently based on their own strengths in shelf construction. However, if you look more closely at user reviews, recurring issues appear with these systems as well, especially deformation under heavy loads and improper assembly.
This is absolutely true, but I want to point out that reliable wall mounting can be problematic in many rental properties (for example, in older buildings with crumbling walls or where landlords have strict rules).
Therefore, alternatives should be stable without wall mounting. In this regard, steel shelves with galvanized frames often offer greater security, while wooden furniture without additional reinforcements is generally only recommended with reservations.
For this reason, I insist that this discussion does not focus solely on classic flat-pack furniture but also considers industrial or workshop shelving, which is often significantly more robust, affordable, and flexible.
