ᐅ Which alternatives to BILLY are recommended for common issues?
Created on: 1 Dec 2016 09:07
Nondan
I am currently looking into shelving units and came across the BILLY shelves from IKEA, which are quite popular. However, I keep hearing from several users about various issues such as stability concerns, difficulties with assembly, and some quality-related doubts.
Therefore, I am particularly interested in the question: What alternatives to IKEA’s BILLY shelves are recommended to address these common problems? It would be helpful if you could specifically address the following points:
- Stability and load-bearing capacity
- Ease of assembly
- Price-performance ratio
- Design options and customization
I am not just looking for any shelf, but a well-considered recommendation that realistically counters the typical weaknesses of BILLY.
Thanks in advance for your insights!
landen
2 Dec 2016 08:56
A bit of lightness shouldn’t be missing 🙂
So, for those looking for alternatives to Billy, the question is also – how manageable does it need to be? If you want a shelf to place somewhere and occasionally rearrange, you should definitely consider sturdier base supports and wall fixings.
I have had good experiences with KALLAX myself. Assembling and disassembling is very easy, and the stability is reasonably convincing, as long as you’re not stacking 100kg (220 lbs) on one level 😉
silako schrieb:
That’s why I insist that in this discussion we don’t just compare classic furniture stores but also consider industrial or workshop shelving
I agree with you there, but that’s more for offices or basements. In living spaces, workshop shelves quickly look a bit "not quite my style" and take away a lot of atmosphere. For the living room or children’s room, you might consider models from USM or Vitsœ – they are perfectly designed but not exactly cheap.
Conclusion: compromises are normal. 🙂
suru61
2 Dec 2016 10:44
landen schrieb:
For the living room or children's room, you could consider models from USM or Vitsœ – they are perfectly designed but not cheap.
That's true, and here it really depends on personal budget and taste. Those who value exclusive design and want fewer issues will do better with these brands.
On the other hand, if you just want something functional and don't want to spend much, you should look at the metal shelving units from Elfa. They offer good stability, are modular, and the height can even be adjusted. Assembly is very straightforward, and their load capacity is generally higher than that of BILLY.
One more tip: sometimes you can find used designer shelves at good prices in local classifieds, which is especially worth it if you’re flexible.
praWarre69
2 Dec 2016 12:09
I agree with the previous recommendations, especially regarding ease of assembly. One issue with BILLY shelves is the rattling and wobbling when fully loaded.
As an alternative, I can recommend "Seville Classics" shelving units, which are often used in home office settings. These steel shelves are sturdy, can be scaled according to individual needs, and use a simple plug-in system without screws – so they are quick to assemble.
suru61 schrieb:
Assembly is very straightforward, and the load capacity is usually higher than with BILLY.
Exactly that – plus, the surface is often coated, making it resistant to scratches. For me, it’s a good compromise between a DIY solution and traditional furniture appearance.
However, the design might not suit everyone, but functionally it is absolutely recommendable.
Fitigu
2 Dec 2016 14:37
In addition to the previous remarks, I would like to address the role of materials:
Wooden furniture like BILLY and Ivar is mainly made from particleboard or solid wood, which behave differently over time. Particleboard tends to swell when exposed to moisture or excessive load, while solid wood can warp if left untreated.
Metal shelving offers better mechanical properties and has been tested in industrial environments. Its disadvantages include less design flexibility and often higher weight.
These factors play a significant role in choosing an alternative and should not be judged solely based on price or appearance.
Ease of assembly is also a consideration: systems with snap-fit connections (e.g., Seville Classics, Elfa) are usually easier for amateurs, whereas wooden shelves often require screw connections, which demand more precise work.
FABIAN_DEO
2 Dec 2016 15:43
Fitigu schrieb:
Wooden furniture like BILLY and IVAR is mainly made from particleboard or solid wood, which behave differently in long-term use.
Environmental impact and sustainability are also important here. Many BILLY models unfortunately use wood that is not very durable, but rather inexpensive materials with lacquer coatings that can be easily damaged by moisture.
For those who value quality, MDF fronts or real solid wood shelves are preferable. Especially with custom-made furniture, you can get significantly more durable products that are also more sustainable.
Additionally, it is important to look for certified wood when purchasing (e.g., FSC or PEFC certification), which is often missing in cheap furniture.
Regarding alternatives: I recommend carefully balancing price, durability, and sustainability, since many inexpensive options end up costing more in the long run if they need to be replaced prematurely.
Nondan
3 Dec 2016 08:05
Thank you very much for the diverse and detailed responses.
To summarize, the following points are particularly relevant to me:
- In my opinion, BILLY’s biggest weakness lies in its construction and the resulting stability, especially without wall anchoring.
- Metal alternatives, such as Elfa or Seville Classics, actually offer convincing stability and ease of assembly but look less homey.
- High-end systems like USM or Vitsœ are design classics but are expensive.
- For a practical solution in a typical household, modular wooden systems like IVAR seem interesting, provided wall anchoring and later reinforcement are taken into account.
- Sustainability and material quality should not be overlooked when choosing.
A question to all: Does anyone have experience with combinations, meaning a basic frame made of metal shelving units with wooden or MDF shelves placed on top? Are there proven systems that allow such hybrid solutions?
Best regards!
