ᐅ What alternative front panel materials are suitable for Ikea BESTA?
Created on: 6 Aug 2021 07:42
sondaryl
I am currently looking into alternative front panel materials suitable for the Ikea Besta system. My goal is to enhance the appearance and possibly the feel of the fronts without compromising storage space or functionality. I am interested in materials that are easy to work with, as durable as possible, and offer an attractive look—whether modern, classic, or customizable. Does anyone have experience or tips regarding veneers, lacquered surfaces, HPL, glass, or other materials? Any advice on installation and compatibility with the existing setup would also be greatly appreciated.
Best regards!
Joshbe
8 Aug 2021 07:27
For clarification: For Besta fronts, a thickness of 18 mm (0.7 inches) is actually the standard recommendation. This thickness ensures sufficient stability and prevents warping.
Aluminum composite panels (e.g., Dibond) are ideal for lightweight and very stable fronts. They are often 3–6 mm (0.1–0.2 inches) thick and consist of two aluminum layers with a plastic core. However, they require an additional substrate made of MDF or plywood to accommodate fixing holes and prevent twisting.
Direct use as a front panel is rare because fastening directly into the material is difficult. With an appropriate substructure, you can create very modern and distinctive fronts.
Regarding veneer, it should also be roughly dried and coated with a protective lacquer to increase moisture resistance.
PULAU
8 Aug 2021 12:31
I would like to add a point that has received little attention so far: surface treatment. Just as important as the material itself is the sealing or finish, as this largely determines durability and ease of maintenance.
If you use wood veneers, I recommend applying several layers of clear lacquer or a natural oil or wax treatment to protect the grain while keeping it visible.
For painted MDF surfaces, the coating should be as durable as possible (e.g., acrylic or PU lacquer) to resist scratches and moisture.
Glass usually only requires cleaning rather than sealing; for visible fingerprints, frosted glass is recommended, while glossy fronts create a wow effect.
A combination of suitable material plus an appropriate finish results in a durable and visually appealing outcome.
REOHEINRIC
9 Aug 2021 09:19
On the topic of compatibility, I would like to add:
Many non-standard materials such as HPL or glass fronts from third-party suppliers need to be precisely cut to align with the Ikea mounting holes. Careful planning of the drill holes is essential; the so-called "drilling template" for BESTA fronts is available online and should be used.
Additionally, I recommend using sturdy substructures or frames for thin materials to increase the lifespan of the fronts and prevent warping.
For custom constructions, also pay attention to the weight that the hinges and fittings need to support. Standard BESTA hinges are designed for moderate weights.
In summary:
- Consider material thickness and weight
- Drill precisely using a template
- Optionally add a substructure
- Do not overlook appropriate fittings
This ensures functionality is maintained and the appearance remains professional.
