ᐅ Where to order bathroom mirrors?
Created on: 18 Jan 2017 12:33
andimann
andimann18 Jan 2017 12:33
So, we have been living in our new house for about 6 weeks now. The old house is finally completely empty and almost ready to hand over. It’s about time to take care of the many small things still missing in the new house.
One of these small things is a bit bigger though: the bathroom mirror is still missing.
The issue: it should be about 200 cm (79 inches) wide and 80 cm (31 inches) high. And as flat as possible. Most online retailers seem to offer mirrors that are 25–40 mm (1–1.6 inches) thick when including lighting, and even the plain mirrors without lighting often have a thickness of 15–20 mm (0.6–0.8 inches). I would like to have it mounted as flush to the wall as possible.
So here’s my question to the group: Where did you order your bathroom mirrors, and where can I find one that sits as flat as possible on the wall?
Thanks and best regards,
Andreas
Benextra18 Jan 2017 22:17
...I gave the local craftsmen a chance and obtained 3 quotes from glaziers (found via gelbeseiten.de). Simple, reliable, fast – done.
18 Jan 2017 22:20
We ordered a custom-sized mirror from badspiegel... however, it is probably 4 cm (1.5 inches) deep, since we used neon tubes.
Bieber0815
18 Jan 2017 22:53
Yellow Pages --> Glaziers. That’s how I would find our local Spiegelmeyer if I didn’t already know them.
kbt09
19 Jan 2017 18:14
At the local art glassmaker, who still etched designs according to choice. Mounted directly on the wall using flat mirror brackets. The front surface is flush, only about 2cm (1 inch) from the wall. Lighting is provided by very discreet surface-mounted fixtures from Paulmann.
I still like it even after 5 years.
meister keks
27 Jan 2017 23:08
Hi.
I ordered my mirror from spiegel21.
The price-to-performance ratio is good, you can choose the sizes and many other options.
The mirror arrived very securely packaged.
I had issues with the infrared transmitter, so I called them and received a replacement free of charge.
