ᐅ What to do if IKEA HEMNES door locks are sticking?
Created on: 29 Oct 2021 18:07
Thorbenso3
Hello everyone, I am currently having issues with the door locks on my IKEA Hemnes wardrobe – they stick and can only be opened or closed with considerable force. The mechanism doesn’t seem completely broken, but the latch catches internally or doesn’t engage properly. It feels like the material may be swelling slightly or the alignment is off. Does anyone have practical tips on how to address this sticking of the door locks on Hemnes without having to disassemble the wardrobes or carry out extensive repairs? It would also be helpful to know if these problems are common and whether special lubricants, adjustments, or small tools might help. Thanks in advance!
roryvin
1 Nov 2021 11:46
Thorbenso3 schrieb:
Does anyone have experience with whether the lock unit in HEMNES is easy to remove and reinstall without needing much realignment?
The main challenge during readjustment when removing and reinstalling is actually the hinge position, rather than the lock itself. The lock unit is usually fixed with two to three screws and aligns with marked positions. Proper marking plus careful handling helps avoid rework.
If you remove the lock, it’s best to mark the screw positions beforehand with a pencil. This way, you can reinstall it exactly in the same spots.
Additional tips:
- Experience shows that the clamp often fits too tightly. Loosening it mechanically a bit (without making it too loose) helps.
- Checking and smoothing edges with a file or vinyl can also relieve pressure without leaving visible marks.
Stay pragmatic; the HEMNES system is robust and modular – well-planned repairs are definitely doable.
