I have a BILLY shelf from IKEA that I mainly use for storing books. Unfortunately, the shelf board bends quite noticeably under load, which worries me regarding its load-bearing capacity and durability. I have already taken into account the maximum weight specified by IKEA, but the effect is still clearly visible.
My question is: What permanent and practical measures would you recommend to prevent or at least minimize the bending of the BILLY shelves when loaded? Should I use replacement shelves made of stronger material, provide additional support under the shelves, or are there other effective tricks?
I look forward to your experiences and practical tips to keep the shelf stable even when fully loaded.
GUSTAVO5614 Jun 2020 07:43ralfsau schrieb:
Simply attach wooden beams or metal braces underneath the shelves.That is a good basic approach, but I would like to explain it in more detail, as success largely depends on the material, the sized support, and the fastening.
First, it is important to know that BILLY shelves are usually made of particle board with a melamine coating. They can carry a uniform load of about 15 kg per running meter (10 pounds per linear foot), which can cause sagging under high loads. The span between the side shelf profiles is typically around 80 to 90 cm (31 to 35 inches). The greater the span, the more noticeable the deflection under load.
To prevent this, I recommend the following options:
1. Reinforcement with support beams: You can screw a thin but strong wooden strip (e.g., made of beech or plywood at least 20 mm (0.8 inches) thick) directly in the center underneath the shelf. This effectively halves the span and significantly increases the load capacity.
2. Install metal brackets or a U-shaped steel profile. Steel profiles with a height of about 20–25 mm (0.8–1 inch) provide excellent stiffness. It is important to fasten them along the entire length of the shelf to prevent local pressure points.
3. Replace the shelf with a board made of MDF or plywood at least 18–22 mm (0.7–0.9 inches) thick. These materials are less prone to bending than particle board.
4. Additional vertical supports: If the shelf height allows, you can also install a small support in the center, such as a narrow board that supports the shelf without impacting the appearance too much.
I would recommend choosing based on aesthetic priorities: metal is robust but visible, while wooden strips are often less conspicuous.
Could you provide more details about the shelf dimensions and the number of loaded shelves? That would help to give a more precise recommendation.
Fuflo10 schrieb:
What permanent and practical measures would you recommend to prevent or at least minimize the sagging of BILLY shelves when loaded?Here are some factual notes on the issue of sagging in BILLY shelves and possible solutions:
- BILLY shelves typically consist of 16 mm (5/8 inch) particleboard with a melamine resin coating. The material stiffness is therefore limited and designed for normal loads.
- The direct load limit of up to approximately 30 kg (66 lbs) per shelf applies only under ideal, evenly distributed loading.
- To minimize sagging, the following methods are recommended:
1. Reinforcement with crossbars or central supports made of wood or metal to reduce the effective span of the shelf and thus lower the bending moment.
2. Use of thicker or higher-quality shelf boards (e.g., solid wood or plywood at least 18 mm (3/4 inch) thick), which provide greater stiffness.
3. Avoidance of concentrated heavy loads, as these promote local sagging.
4. If applicable, additional vertical supports underneath the shelves can help distribute the load more evenly.
In summary, shelves should either be reinforced, replaced with stiffer materials instead of thinner or softer ones, or mechanically relieved by additional supports to achieve the desired long-term stability.
