ᐅ What issues arise when installing Billy in hobby cellars?
Created on: 28 Mar 2022 18:37
Meroni40
Meroni40
28 Mar 2022 18:37
Hello everyone, I am currently planning to assemble a Billy bookcase in my hobby basement, but I am encountering some difficulties and wanted to ask the community: What typical problems arise when installing Billy bookcases specifically in hobby basements? I am particularly interested in challenges caused by factors such as humidity, uneven floors, limited space, or special room conditions. Are there any tips on how to ensure stability despite these conditions? I would appreciate any experience shared, as I intend to use the bookcase long-term and want to avoid issues with leaning shelves or moisture damage.
bapar
28 Mar 2022 20:25
Hello Meroni40, your topic is really interesting and quite relevant in practice. I have installed Billy shelves in basements several times, and there are some typical challenges that I would like to explain to you in more detail.
First of all, moisture in the basement is a critical factor. Billy shelves are mainly made of particleboard-based materials, which can swell or warp if the humidity is too high. Therefore, I recommend measuring the moisture level in the room before installation and using a dehumidifier if necessary. A basement hobby room is often more susceptible to temperature and humidity fluctuations, which can cause deformation over time.
Another point is uneven floors, which are common in older basements. Do you have the possibility to accurately measure the floor before setting up the shelves? Unevenness can cause the shelves to wobble or stand awkwardly later on. One solution can be to install adjustable feet or place suitable pads under the shelves to align the unit properly.
Basement walls can also be rough and irregular. When attaching the shelves, especially if you want to anchor them to the wall, it is important to use the correct material for anchors and screws—often special basement wall anchors are used that provide good hold in porous or damp walls.
A question for you: How exactly is the condition of your hobby basement regarding moisture and floor surface? Have you already chosen a suitable spot? This information is important to give more targeted advice.
I hope my initial assessment helps you. I am happy to provide more detailed tips if you describe the specific conditions.
kloreo
28 Mar 2022 21:46
I would like to add a brief note that during the installation of Billy shelves in hobby basements, a common issue often occurs: poorly aligned shelves. I recommend fully adjusting the shelves before assembly and, if necessary, using small wooden wedges underneath to ensure stability.
Also, don’t forget to securely fix the shelves to the wall to prevent tipping – especially in basements with moisture, where problems can arise quickly.
Guyju
29 Mar 2022 09:14
Hello Meroni40,
I will summarize and add a brief practical guide for installing Billy shelves in hobby basements, based on common issues:
1. Preparing the room:
- Measure humidity: Use a hygrometer to check the air humidity. Ideally, it should be below 60%.
- Level the floor: Before assembly, even out any unevenness using wooden shims or furniture glides.
2. Choosing the right material:
- Billy shelves are typically made from coated chipboard. For damp basement rooms, it makes sense to use water-resistant variants or protective coatings.
3. Installation:
- Use adjustable shelf feet to compensate for uneven floors.
- Don’t forget to anchor the shelves to the wall – use sturdy wall plugs and make sure to select suitable screws for concrete or brick walls.
4. Long-term protection:
- Avoid standing moisture and regularly monitor the room’s air.
- Position shelves away from damp walls to promote air circulation if the wall is prone to moisture.
kloreo schrieb:
Always secure shelves to the wall to prevent tipping hazards
I fully agree with this advice; it’s an essential measure. Additionally, if possible, you should also avoid placing shelves directly on cold or damp basement floors.
Do you have any specific floor conditions or wall substrates you can describe? That way, we can customize the recommendations further.
