ᐅ What are the most common issues encountered when assembling the IKEA BRIMNES furniture?
Created on: 1 Oct 2023 08:12
X
xaver4Hello everyone,
I would like to start a more detailed discussion on the topic "What are the most common problems when assembling the IKEA Brimnes?" Specifically, I’m interested in the typical difficulties and sources of errors that users frequently encounter during assembly of this model—whether related to the instructions, the fit of the parts, the tools required, or the stability after assembly.
I’m particularly curious if there are inherent weak points in the design that regularly cause issues, or if the problems are usually due to user mistakes. Additionally, it would be helpful to get advice on the best ways to avoid or resolve these problems.
I recently assembled it myself and mainly encountered problems with aligning the drawer fronts and the fastening instructions. Therefore, I look forward to hearing about your experiences and opinions!
The following issues are most common when assembling the IKEA BRIMNES:
- Inaccuracies in the drilling, which can make it difficult to insert the dowels
- Unclear or sometimes confusing instructions, especially when installing the drawer slides
- Challenges in aligning the drawer fronts exactly, due to limited adjustment options
- Lack of stability if the connections are not executed precisely, particularly noticeable under heavy loads
To avoid these problems:
- Carefully check and pre-drill if the included tools do not fit exactly
- Follow all steps carefully without shortcuts
- Assembly is often easier with an additional helper when aligning the fronts
In general, I recommend partially inserting all screws multiple times before fully tightening, and deliberately aligning the parts. This helps prevent issues with fitting accuracy.
Dopoki schrieb:
Inaccuracies in the drilling, which can make it difficult to screw in the dowelsThat’s true, especially with BRIMNES, the drilled holes are sometimes slightly misaligned, making precise assembly challenging. I also often see screws being tightened too quickly or too firmly before everything is properly fixed. This causes warping issues and complicates the later installation of the drawers.
Dopoki schrieb:
Unclear or partly confusing instructions, especially when assembling the drawer runnersIn these cases, it’s important to carefully follow each step without skipping anything, since some parts of BRIMNES are not intuitive. A helpful approach is to lay out all the parts beforehand and compare them with the pictures in the manual to avoid mix-ups.
Additionally, I recommend using good tools, as the included Allen key is often stiff, which can damage the screws more quickly.
A quick tip regarding drawer fronts: alignment can be tricky with BRIMNES because the screws allow only minimal adjustment. It’s better to loosely attach the fronts first, tighten all screws lightly, and then gradually make adjustments.
Also, always double-check that all parts are installed the right way around, as this is a common source of errors. Incorrect orientation can quickly lead to misaligned gaps or uneven fit.
