ᐅ What helps with squeaky Billy doors?
Created on: 10 Jan 2020 20:17
ROREPRA
ROREPRA
10 Jan 2020 20:17
Some time ago, I noticed that the doors of my Ikea Billy bookshelf started making squeaking noises when I open or close them. It’s quite annoying because it sounds really unpleasant and reduces user comfort. Before I go ahead and replace parts or take the shelf apart, I wanted to ask:
What methods, remedies, or techniques do you know for fixing squeaky doors on a Billy bookshelf? I’m interested in both simple, quick tips as well as tools or products that prove effective in the long term.
Are there specific lubricants you would recommend? Or are squeaks more often caused by installation errors or misaligned hinges?
I would really appreciate practical suggestions and experiences, maybe also advice on what to avoid. Thanks in advance!
TARAON
10 Jan 2020 21:43
Hey, I know that squeaking on Billy doors all too well – it’s like a little horror movie in the living room ;-)
Generally, a bit of lubrication helps, but it doesn’t always have to be WD-40, since it’s great at stopping the squeaks but tends to attract dirt and dust. I prefer regular silicone or graphite sprays because they don’t stick and stay cleaner for longer. Just spray a few bursts on the hinges, then open and close the door a few times – voilà, silence.
Sometimes there’s simply dirt or rust inside the hinge, so clean it first, for example with an old cloth or a small brush. In rare cases, the screws on the hinges can be loose, which also causes squeaking, so check and tighten them if needed.
ROREPRA schrieb:
Or is it more likely installation errors or misaligned hinges causing the squeaking?
I can only confirm that – on my doors, two screws were slightly loose, which made a small but noticeable difference.
Good luck, and remember to use lubricants sparingly so you don’t end up with an oily apartment 😉
Cheers!
rubybi
11 Jan 2020 08:36
Hello ROREPRA,
your description is quite precise, and this topic is relevant for many users with Billy shelves. Here is a brief guide on how I would approach eliminating the squeaking:
1. Analysis: The squeaking usually comes from the hinges. Open the door, observe the movement closely, and identify where the noise is coming from.
2. Cleaning: Dirt or old paint often gets into the moving parts. Use a lint-free cloth and possibly some isopropanol to clean the hinges.
3. Lubrication: Use a silicone-based lubricant or a special hinge oil. Avoid using WD-40 as a long-term solution, as it is more of a penetrating oil for initial treatment.
4. Check the screws: Make sure the screws in the hinges are not loose, as this causes unnecessary friction.
5. Adjustment: Sometimes slight adjustments help. On Billy shelves, the door catch can be readjusted to reduce tension on the hinges.
6. Additional tips: If the squeaking persists after several lubrication attempts, the nylon bushings or plastic bearings in the hinges might be damaged. Replacing these parts can help.
In summary: Clean any dry or dirty spots, lubricate, check the screws, and if needed, adjust – this is sufficient in most cases.
Good luck! 🙂
rebufar
11 Jan 2020 21:02
TARAON schrieb:
I know the squeaking on Billy doors all too well – it’s like a little horror movie in the living room ;-)
Personally, I think the squeaking Billy doors get way too much of a soft, exaggerated reputation. Sure, they’re annoying, but isn’t that just a typical issue with the materials and construction?
rubybi schrieb:
no WD-40 as a permanent fix, it’s more of a penetrating oil for initial treatment
I totally agree. WD-40 is way too often promoted as a cure-all. It quiets things down temporarily, but in the long run, it actually attracts dirt. It’s better to follow the hinge manufacturer’s recommendations and maybe treat the doors differently: open and close them several times firmly so the joints can wear in a bit.
I’d argue: constantly spraying lubricant on Billy doors actually causes them to wear out faster or even stick.
You could also consider that the creaking might just indicate that the shelf doors aren’t designed for high-quality standards, and it might be worth investing in alternative products if you want quiet. But of course, that’s a luxury solution.
In any case: clean thoroughly, avoid WD-40, and apply only minimal, suitable lubrication—that should be enough.
