I have several furniture pieces from the IKEA Hemnes series, including dressers and bed frames, where some parts have been squeaking for a while. The noise mainly occurs under load, for example, when opening drawers or lying on the bed.
From my observation, the sounds mostly come from wooden joints and moving parts that seem to have some play.
Since I want to fix this problem permanently, my question to you is: What are practical, effective ways to stop squeaking IKEA Hemnes furniture parts for good? Are there specific products or methods that work especially well for the wooden components in this model?
I look forward to your experiences and tips!
praWarre6915 Jun 2022 11:48Hey Gatar0,
first of all: the annoying squeaking is a common issue with Hemnes and similar furniture 😅 My advice is that for wooden joints, it usually helps to use lubricants or small washers.
- Simple solution: woodworking techniques, like applying a bit of wax or candle wax to the rubbing areas.
- Graphite powder is also a secret helper if you have any.
- Sometimes the squeaking happens because screws are not tightened properly anymore – it’s worth checking and retightening if needed.
Sometimes a bit of trial and error is all it takes, especially in hard-to-reach spots. With some patience, you’ll definitely get it sorted! 😉
Hello Gatar0,
I would like to add a few points to what praWarre69 mentioned, as these are often overlooked:
- First, check if all screws and fasteners are really tight, since loose connections are often the cause of noises.
- If the screws are tight, the squeaking might be caused by wood-on-wood contact or friction on the bearing surfaces.
- In this case, a thin layer of furniture wax or silicone spray is recommended, although silicone spray should be used sparingly to avoid stains. It’s better to spray it onto a cloth first and then apply it.
- Alternatively, a special furniture oil might also help.
- If you have visible wood screw joints, small felt or plastic washers can be used as spacers to reduce friction.
It’s important to proceed carefully and test whether the measures help, in order to find the best solution for your furniture.
If you like, please describe exactly which piece of furniture is squeaking and during which movement – sometimes this allows for more specific advice.
Very good question, Gatar0. To resolve squeaking parts in IKEA Hemnes furniture, I recommend the following structured approach:
- First, carefully check that all screws are tight and tighten them if necessary.
- Then, check if wooden parts slide slightly against each other, causing friction.
- For lubrication, furniture wax or paraffin (candle wax) is suitable. Apply it thinly to the contact surfaces using a cloth.
- Silicone spray can be used, but caution is advised as it may cause stains. An alternative solution is beeswax or graphite powder.
- Avoid using oil on wood joints, as it can cause the wood to swell, which may lead to problems.
From a technical perspective, felt or plastic pads can also be applied as buffers on particularly movable parts. These improve cushioning of movements and reduce noise.
The Hemnes series often uses solid pine wood, which naturally responds to changes in humidity and temperature to some extent. Therefore, adjustments after prolonged use are normal.
I hope this provides you with a comprehensive guide to solving the problem.
I want to contribute to this topic because often, with "squeaky furniture," only the symptoms are addressed without truly analyzing the root cause.
In my opinion, this is exactly the core of the problem. Changes in moisture content cause minimal expansion or contraction, which can lead to joints no longer fitting perfectly. The squeaking is often the result.
Therefore, I think it is very important to control the environment: the room’s humidity should be kept as stable as possible, for example, monitored with a hygrometer.
Another question would be whether the furniture has been used for several years or if it is new.
I believe that those who try to fix the squeaking only by applying wax or tightening screws are only temporarily addressing the symptoms, not the root cause.
For this reason, I would recommend in the long term:
- regularly checking the furniture,
- maintaining a consistent indoor humidity,
- and proactively adjusting if there are significant changes in humidity.
It is a combination of material properties and environmental conditions working together here.
KAMERON schrieb:
The Hemnes series often uses solid pine wood, which reacts slightly to changes in moisture and temperature.
