ᐅ What can be done to prevent paint from peeling off Malm furniture?
Created on: 14 Aug 2020 10:37
Ta_pau68
Ta_pau68
14 Aug 2020 10:37
I recently purchased some Malm furniture from IKEA, but I have started to notice an unpleasant issue: the surface is rubbing off in several places, especially when it comes into contact with a dark cloth or clothing. The color loss is mainly visible on edges and areas that are touched more frequently.
Since I would like to use the furniture for a long time, I want to know what products or methods exist to effectively prevent or fix this problem of color loss on Malm furniture.
Are there specific sealants, varnishes, or care products that can help? Or are certain cleaning methods actually counterproductive?
I look forward to your experiences and recommendations on how to protect the material from further peeling or whether it is possible to repair the furniture surface. Thank you in advance!
floga
14 Aug 2020 12:29
This is really frustrating, and you don’t often experience something like this with new furniture.
Ta_pau68 schrieb:
The surface discolors especially on edges and areas with frequent contact.
I noticed the same issue with a Malm desk. For me, carefully treating the surface with furniture wax helped. It didn’t completely stop the discoloration, but it significantly reduced it and made the furniture look fresher.
At first, I was worried that this might make things worse or cause chemical damage, but so far everything has been fine. Maybe a smoothing layer is indeed a good way to protect the color.
When it comes to cleaning products, I would definitely avoid aggressive cleaners and prefer only gently damp cloths.
I’m also curious if anyone else has had different experiences, especially with lacquers or sealants?
O
olivernu
15 Aug 2020 09:12
Basically, the surface of Malm furniture is usually made of a thin melamine or foil coating, which is quite sensitive to mechanical abrasion and moisture.
floga schrieb:
I initially had concerns whether this might make things worse or be chemically unfavorable
That is indeed an important point: not every treatment is compatible with the original coating. Special clear coats or acrylic sprays can provide additional protection but should ideally be tested first on an inconspicuous spot.
I recommend checking the composition of the furniture surface before taking any such measures (sometimes this information is on the back or in the product details).
A sensible first step is cleaning with mild soap and a soft cloth. Then, very carefully smoothing rougher areas with fine sandpaper (grit 400 or higher) can help before applying a suitable sealant available at hardware stores or specialized furniture shops (for example, water-based clear coats).
The rule is: apply several thin layers, allow each to dry, and avoid applying too thickly to prevent cracking or peeling.
roryvin
15 Aug 2020 15:45
In summary, the issue of paint peeling on Malm furniture is often caused by the limited durability of the foil or melamine coating.
olivernu schrieb:
Special clear coats or acrylic sprays can provide additional protection but should ideally be applied only after testing on an inconspicuous area first.
This approach is correct and important to avoid unwanted reactions.
Additionally, it should be noted that cleaning with harsh agents or excessive moisture can weaken the adhesion of the foil and lead to peeling.
The durability of the surface can be improved by light sanding followed by the application of a suitable transparent protective lacquer.
When in doubt, it is advisable to use products specifically designed for laminated furniture. Furniture should ideally be cleaned with a damp, mild cloth and wiped dry quickly to avoid prolonged dampness.
Preventing mechanical scratches or abrasive materials is very important as a preventive measure.
Palenar
16 Aug 2020 20:03
I would like to add that the surface quality of Malm furniture is often quite basic due to the low price, so frequent mechanical stress, such as regular bumps from rings or sharp objects, can quickly cause color wear.
roryvin schrieb:
The durability of the surface can be improved by light sanding followed by applying a suitable transparent protective varnish.
However, extreme care is needed when sanding. I recommend the following step-by-step method for anyone who wants to treat their surface:
1. Gently clean and degrease with alcohol solution or a mild cleaner.
2. Very carefully sand lightly with 600-grit sandpaper to avoid completely damaging the surface texture.
3. Thoroughly remove dust, ideally with an anti-static cloth.
4. Apply a thin coat of water-based clear varnish using a fine brush or small roller.
5. Let dry for at least 12 hours, then apply a second coat the same way if needed.
Note that the varnish is still very sensitive during the first application and should not be wiped with a wet cloth.
Also, the temperature during application and drying should be kept as constant as possible and not too cold.
For furniture with visible paint peeling, completely rebuilding the surface by sanding and varnishing can significantly extend its lifespan, even though the effort is somewhat greater.
In conclusion: for a quick improvement in everyday use, furniture wax can noticeably enhance the appearance, but it does not solve the peeling problem itself.
If anyone needs more detailed information about types of varnish or sources for suitable materials, I am happy to help.
