ᐅ What are some hacks for using Ikea BRIMNES furniture?
Created on: 20 Jul 2022 10:13
Koplo2
Koplo2
20 Jul 2022 10:13
I recently bought some furniture from the Brimnes series by Ikea and am now considering how to expand or improve it in a clever way. Especially with collections like Brimnes, which have a fairly simple design, I am interested in creative hacks that enhance both functionality and personalize the look.
Specifically, I am looking for hacks or modifications that optimize storage space, make pieces multifunctional, or unlock unexpected uses. Perhaps someone has experience improving drawer safety, adding extra compartments, or integrating cable management, which is often lacking in Brimnes?
I look forward to practical suggestions, preferably with advice on materials, tools, or effort involved.
klo61
20 Jul 2022 11:07
Good question, BRIMNES really is a great base for modifications.
I have the following ideas that are easy to implement and make everyday life easier:
- Cut drawer liners from thick felt or foam rubber to prevent slipping and reduce noise.
- Drill cable outlets into the back of the dressers afterwards, so you can neatly hide power strips.
- For better organization, use short telescopic rods or small shelves that can be inserted into taller drawers.
- To give the bed box door more stability, you can replace torque hinges with stronger ones.
I usually get materials at the hardware store; most of this can be done with simple tools like a drill, screwdriver, and some sandpaper. If you need detailed instructions, I’d be happy to provide them.
Trate47
20 Jul 2022 12:45
Exciting topic! BRIMNES really is a kind of blank canvas for DIY enthusiasts.
A cool hack that comes to mind is adding self-adhesive magnetic strips to the headboard panels and then attaching smaller storage elements, like small boxes or even lamps, with magnets.
This way, a simple bed transforms into a multifunctional comfort zone – perfect for book lovers or binge-watchers.
Additionally, you can paint the inside of the drawers or cover them with wallpaper to give the furniture a personal touch without much effort.
KUDAISY
21 Jul 2022 08:02
To expand and improve Ikea BRIMNES furniture, I would like to propose a structured approach based on my own experience:
1. Increase storage space: The inside of the drawers can be divided using self-adhesive dividers made of plastic or wooden panels. Note: precise measurements are crucial to ensure the drawers still close smoothly.
2. Enhance drawer safety: One option is to install so-called drawer stoppers (available from furniture accessory suppliers) on the sides or back, preventing the drawers from being pulled out too far.
3. Cable management: Often, there is no built-in cable channel. It is advisable to attach narrow cable holders or clips (e.g., 3M Command Clips) to the back of the dresser to avoid tangled cables.
4. Customize the appearance: Self-adhesive films or matte paints look more premium than the original finish. Painting surfaces can be prepared with fine sandpaper to improve durability.
5. Tool tips: For all these modifications, a drill, cordless screwdriver, screwdriver, and a utility knife are sufficient. When using the utility knife, prioritize safety.
This systematic approach helps to avoid overlooking any details and effectively upgrades the piece of furniture.
dosogau
21 Jul 2022 12:17
This works really well for me. I also like to use boxes that fit perfectly to maximize the use of space.
klo61
22 Jul 2022 09:36
Trate47 schrieb:
A clever hack that comes to mind: You can attach self-adhesive magnetic strips to the headboard panels and then fix smaller storage elements, such as small boxes or lamps, using magnets.
A very nice idea for more flexibility at the bed! Additionally, I recommend using sufficiently strong magnets (neodymium magnets) for such magnetic solutions. This ensures everything stays securely in place, even if you pull on it firmly.
Also: If the surface of the headboard panels is sensitive, I suggest applying a protective layer first (e.g., clear varnish) to prevent any damage.
A note regarding drawer stoppers: If you want to avoid expensive stoppers, you can attach felt pads to the inside of the drawer back panel. These prevent the drawer from sliding out completely, with gentle cushioning.
