ᐅ What should I do if the joints in my Billy shelves are damaged?
Created on: 29 Aug 2024 18:23
Jontepo49
Jontepo49
29 Aug 2024 18:23
Hello everyone, I have a problem with one of my BILLY shelves where the joints between the shelves and the side panels no longer hold properly. Specifically, I mean the small dowel holes that often become soft or worn out, causing the shelves to wobble or even fall out when loaded.
What is the best way to repair or reinforce these joints to make them as stable as possible? I prefer to avoid buying many replacement parts and would like to use simple methods that still work well from a craftsmanship perspective. Perhaps someone knows a tried-and-true method or a material that works well to secure the dowel holes again without having to take the entire shelf apart?
Thanks in advance for your tips and experiences!
Maria35
29 Aug 2024 19:08
Hello Jontepo49,
A common issue with BILLY shelves is that the dowel holes can soften due to stress or moisture. For a long-lasting repair, I recommend the following procedure:
1. Carefully remove the affected shelves.
2. Clean the dowel holes from dust and old wood residues.
3. Fill the holes with wood glue and pieces of wooden dowels or toothpick wood, cut flush.
4. Let the glue dry thoroughly (at least 24 hours).
5. Then reinsert the shelves with the dowels—the glue will provide a much stronger bond.
Alternatively, special wood filler putty can be used if you don’t have the right dowels, but the glue and dowel method is more stable.
Important: Make sure the parts fit precisely to avoid causing new damage from filler pieces that are too large or too small. The shelf should stand on a level surface to prevent warping.
Palenar
30 Aug 2024 08:47
Maria35 schrieb:
Fill the holes with wood glue and small pieces of wooden dowels or toothpick wood, cut flush.
That is correct and a proven method that I often use myself. I would like to add a few points to consider:
If the dowel holes are enlarged quite generously, it is often not enough to use just glue with filler pieces, since the bond still depends on the outer wall of the hole. In this case, you can slightly enlarge the hole to fit a thicker wooden dowel of the appropriate diameter. However, this requires some craftsmanship skills and the right tools (drill, dowel setter).
If you don’t want to completely disassemble the shelf, you can also use so-called “wood repair sticks” (hardwax sticks). These are heated and pressed into the damaged opening, then cool and harden – providing a strong hold and lasting durability.
One more tip: If you cannot install suitable wooden dowels, you can alternatively drill much smaller holes and insert small screws with appropriate washers to prevent pull-out. However, this is somewhat more invasive and may stress the original shelf board over time.
Could you describe more precisely whether the stability is only affected in the area of a single board, or if several joints are involved? In that case, retrofitting additional corner braces might be an option.
warrenka57
30 Aug 2024 15:16
Hello Jontepo49,
I completely understand how frustrating it is when a shelf wobbles or feels unstable. That has happened to me as well, especially with older shelves or those that have been moved around frequently.
Sometimes it helps to take the shelf apart completely, remove the old wall plugs, and re-glue everything. I know this takes time and patience, but it worked best for me. I also had good results with a special repair kit designed specifically for BILLY shelves from IKEA.
If that’s not an option, try checking if the shelf is firmly against the wall and whether the floor is level. Often the cause is there, and small adjustments can make a big difference.
I hope you’re able to get the shelf stable again. 🙂
