I recently bought a Hemnes bookshelf from Ikea and would like to know if you have any DIY tips specifically for this series. I am especially interested in ideas on how to enhance the appearance of the shelf without compromising its stability. For example, I’m looking for ways to treat the wood individually or to add special character through small craftsmanship adjustments. Maybe you also have suggestions for a practical interior layout or smart additions that make the shelf more functional? I’m really looking forward to your experiences and sustainable ideas that go beyond simple rearrangements.
A very interesting topic – especially the HEMNES series offers many creative possibilities thanks to its classic design that go far beyond simple storage.
Basically, I recommend first considering the specific type of wood used for the shelf: HEMNES is usually made of solid pine wood, which makes it easier to apply stains, oils, or varnishes. It is important to lightly sand the surface with fine sandpaper before any treatment – preferably evenly and in the direction of the wood grain.
For example, you can create a whitewashing effect (applying diluted white paint and then partially wiping it off) to make the shelf look bright and airy without fully covering the wood. Important: use breathable products to avoid sealing the wood’s natural texture.
For functional improvements, I suggest:
- Adding extra shelves to optimize storage space
- Using adjustable metal brackets if not originally included
- Installing hanging hooks or small baskets that can be attached to the sides
Don’t forget to securely fix the shelf to the wall, especially if it is tall or will hold heavy items.
Another great idea is to replace the back panel with a thin wooden board covered beforehand with patterned film or wallpaper – this can turn the shelf into a real eye-catcher!
I would be interested to know which room the shelf will be placed in and whether you prefer a rustic or modern style?
As a supplement:
There is a proven method to customize HEMNES shelves individually without compromising stability by using retrofit kits with special insert or drawer elements that fit the internal dimensions. This significantly enhances functionality.
For surface protection, I recommend using a thin layer of hardwax oil instead of lacquer, as it provides lasting protection while highlighting the wood grain.
Additionally, the back panel can be removed and replaced with a perforated board that serves as a mounting surface for hooks or small shelf baskets – greatly increasing flexibility.
Installing LED strips under the shelves also improves usability and creates a modern atmosphere. Battery-operated models are recommended to avoid running cables.
One final note: Be sure to pay attention to the load capacity of each shelf, especially under heavy loads, to ensure the furniture’s durability.
