ᐅ What common mistakes occur when assembling Ikea Hemnes furniture?
Created on: 6 Jan 2018 08:37
Geharis
Geharis
6 Jan 2018 08:37
I am planning to assemble an Ikea Hemnes piece of furniture soon, but I have already read quite a bit about the common pitfalls and mistakes that often occur when building Hemnes items. Since I want to have a smooth and stress-free assembly process, I would like to know: In your experience, what are the most frequent errors when assembling Ikea Hemnes furniture? Are there any specific tips or tricks to avoid these mistakes? I would appreciate detailed advice, ideally related to the individual steps or the handling of the parts. Thanks in advance!
Alberto51
6 Jan 2018 09:12
Hello Geharis,
your question really hits home for me, as I also had quite a hard time with the last Hemnes assembly. One of my biggest issues was definitely figuring out the orientation of the parts – the instructions are good overall, but sometimes they can be misleading.
It often happens that screws or dowels are placed in the wrong spots, which later causes instability. I also found that it’s easy to scratch the wooden panels if they are not laid down properly or if you apply the wrong amount of force during assembly.
Geharis schrieb:
What are the most common mistakes when assembling the Ikea Hemnes, based on your experience?
I would also say patience is important here, because working too quickly or carelessly often leads to unnecessary mistakes. Always pay close attention to the angles when fitting the fittings and especially check if holes are pre-drilled – sometimes they are barely visible.
I’m curious if others have had more difficulties at certain steps, such as installing the back panel or working on the drawers.
fajan
6 Jan 2018 17:46
Hello Geharis and everyone else,
I would like to provide a more detailed response since the topic of Hemnes and Ikea furniture assembly often raises questions. Generally, the most common mistakes with Hemnes furniture are the following:
- Confusing side panels or plywood boards, as they often look very similar
- Turning screws or fasteners in the wrong direction (which requires rework)
- Ignoring designated alignment points, such as holes for screws
- Skipping steps because you think the process can be done faster
- Using too much force, which can damage the wooden parts
I recommend sorting all parts and carefully comparing them with the instructions before starting assembly. The back panel is often installed too early or incorrectly, which can cause stability issues later depending on the piece of furniture.
Often the issue is that the instructions were not read thoroughly, or too much reliance was placed on supposed prior experience. It is therefore important to proceed step by step and always check the parts before assembly.
Is there a specific Hemnes model where you suspect the problems? Then I can help you even more specifically.
matskeo
7 Jan 2018 07:59
the most common mistake I see is that the screws are inserted the wrong way around. Sometimes wooden dowels are forgotten or not properly glued in.
In addition, the parts should always be sorted according to their numbers and not assembled randomly.
FAZAR
8 Jan 2018 13:03
I would like to add to the discussion with a more detailed insight. As someone who has assembled many Ikea furniture pieces, including several Hemnes models, I can say that smaller challenges are often underestimated here.
First and foremost is precise preparation: Check all wooden parts for damage, read the instructions several times, and have the screw types (Phillips, slotted, or Allen/hex) ready before starting.
Common mistakes with Hemnes:
- Most difficulties arise when aligning the side panels with each other – if this is not done precisely, the entire furniture frame becomes misaligned.
- The back panel is sometimes installed with too much force, causing the material to tear or the piece to warp.
- Another frequent mistake is confusing screw types, which can look very similar (for example, longer versus shorter screws). This can be hard to spot at first glance and can seriously affect stability.
- For drawers, special attention must be paid to the runners: if these are not installed perfectly parallel, the drawer may catch or not close properly.
- Door assembly can become tricky if the hinges are not adjusted correctly – fine adjustments are recommended after the initial installation.
Besides these technical aspects, I often notice problems with time planning. Many want to achieve success too quickly and overlook details that ultimately delay assembly or cause damaged parts.
I would be interested to know if you, @Geharis, have already taken any steps or if we are starting from scratch? Then I could offer you more targeted advice.
