ᐅ What can you do if the screws in Ikea BRIMNES furniture come loose?
Created on: 23 Aug 2020 08:12
Jo_ben
Jo_ben
23 Aug 2020 08:12
Hello everyone, I have an issue with my Ikea Brimnes bed, specifically with the screws that often come loose. This mainly affects the connection points between the side panels and the headboard and footboard, as well as the screws holding the backrest. Despite regular checks and tightening, I keep having to retighten the screws, which is obviously annoying over time and seems difficult to solve.
My question to you is: What can be done when the screws on an Ikea Brimnes bed keep coming loose? Are there proven methods to reliably prevent the screws from loosening again? For example, special tools, different screws, or tips during assembly? I would really appreciate your advice and as detailed explanations as possible, as I would like to fix this problem once and for all.
nera59
23 Aug 2020 10:37
Hello Jo_ben,
I’m familiar with the issue of screws loosening in furniture like the Ikea BRIMNES. Here is a structured approach to help solve the problem:
- Step 1: Completely loosen the screws and inspect all furniture parts. Sometimes the holes are slightly enlarged or the wood has become worn, which can cause the screws to loosen.
- Step 2: Clean the screws and the threads of the connecting parts to ensure no dust or grease weakens the connection.
- Step 3: For better fixation, it is recommended to use a threadlocker – for example, a blue medium-strength threadlocker that can be removed if needed.
- Step 4: Reinsert the screws and tighten them with the appropriate torque, not too tight to avoid damaging the material, but tight enough for a secure hold.
- Additional tip: If the wood around the screw holes is already very worn, you can insert small wooden pieces or toothpicks with wood glue into the holes before screwing in again. This provides renewed stability.
Summary: The combined approach of checking the wood, cleaning, using threadlocker, and repairing the holes if necessary often works very well.
If you like, I can also provide some product recommendations for threadlocker and special wood repair materials.
RonJarrett
23 Aug 2020 11:45
To add to nera59’s points:
Ikea BRIMNES furniture is typical flat-pack furniture, often supplied with fittings that are acceptable for the price but tend to loosen under heavy use or frequent handling.
My specific recommendations are:
- Use medium-strength threadlocker (e.g., Loctite 243) to prevent screws from loosening due to vibrations without damaging the screws permanently.
- Check if you can replace the original screws with higher-quality ones (stainless, harder steel alloys).
- Retighten the screws about two days after assembly, as some settling usually occurs with initial twisting.
- Inspect whether the connecting system (e.g., dowels, metal brackets) is fully and correctly installed, since wobbling often results from incorrect assembly.
These measures are practical and based on experience, generally resulting in a significantly more stable piece of furniture.
GEKAU51
23 Aug 2020 12:20
nera59 schrieb:
If the wood around the screw holes is already quite worn out, you can insert small wooden pieces or toothpicks with wood glue into the holes
This is, of course, a classic tip that often comes up, but honestly, I wonder: why should we bother with such temporary repairs at all?
Furniture like BRIMNES is mass-produced economically, and if the screws loosen, it’s probably because very cheap materials and construction methods were used. My suggestion: instead of repeatedly tightening or patching the screws, treat the piece as functional furniture that will eventually be replaced or upgraded with better joining techniques.
I’m not saying you should just throw it away immediately, but all this fixing seems like a quick patch to me. It might be more worthwhile to replace the screws with stronger, longer, or even self-locking screws or to reinforce the whole thing with metal brackets or connector plates.
Simply using wood glue or thread-locking fluid won’t solve the underlying problem.
pauPierce
24 Aug 2020 07:22
I would like to go into more detail here because the reasons for loosening screws in furniture like Ikea BRIMNES are often quite complex.
It is important to understand that the base material in BRIMNES is usually particleboard or MDF with a veneer finish. These boards have relatively high strength, but the screw holding power is limited due to the wood particle structure.
If the screw keeps wobbling, micro-movements cause the screw hole to enlarge, also known as thread stripping. This especially happens with repeated tightening and loose screws.
Technical steps to solve the issue:
- First, completely disassemble the furniture to allow stress-free inspection and testing of the screws.
- Repair wood with wood filler or epoxy resin for worn-out screw holes. Completely replacing the material improves the tensile strength.
- Use threaded inserts (brass or metal sleeves) that can be pressed into the original hole. This greatly improves screw retention but is somewhat more complex.
- Always use thread locking compounds, preferably a medium to strong anaerobic adhesive that withstands vibrations.
- Assemble using a torque wrench to avoid over-tightening.
Regarding assembly practice: Do not fully tighten all screws at once. First, insert all screws loosely, then gradually tighten them so the components can settle without tension.
Could you specify which screws and joints are affected (for example, the connection of the side panels with metal brackets or simple wood screws)? That would help to provide more precise recommendations.
Jo_ben
24 Aug 2020 10:03
pauPierce schrieb:
Could you specify which screws and connections are affected?
Good point! Specifically, it mainly concerns the four screws that connect the side panels to the headboard and footboard. These screws are relatively large (about 6 mm diameter (0.24 inches)) and are used together with metal brackets. Additionally, there are smaller screws that attach the backrest (also into MDF boards), which also seem to loosen frequently.
So far, tightening has mostly been done without a torque wrench, simply using a screwdriver and feel. The screws are the original ones from Ikea, no replacement parts have been used yet.
