ᐅ What installation issues are common with Ikea Hemnes furniture?
Created on: 6 Mar 2020 18:37
Dano5
Dano5
6 Mar 2020 18:37
Hello everyone, I recently tried assembling an IKEA Hemnes wardrobe and noticed some recurring assembly issues that I would like to discuss with you. Specifically, I’m referring to difficulties when joining the individual parts, such as precisely aligning the drill holes, fitting the wooden components accurately, and problems with the included screws and fittings. Additionally, I found the instructions somewhat unclear at times, especially for more complex assemblies like drawers or doors. What assembly problems have you experienced with IKEA Hemnes? And what tips or tricks can you recommend to make the assembly significantly easier? I look forward to your feedback and experiences.
Daledra
6 Mar 2020 19:22
The drill holes often do not align perfectly, which results in misaligned parts. Screws should not be tightened too much, as this can cause the wood to split. Additionally, the instructions can sometimes be misleading, especially when installing the door. It is best to sort everything out before assembly.
taudi
6 Mar 2020 20:03
To ease the common assembly issues with the IKEA Hemnes, I recommend the following approach:
- Step 1: Check all pre-drilled holes for accuracy, as they are often slightly offset. It helps to make minor adjustments with a chisel or a fine file.
- Step 2: Initially tighten all screws only by hand, and only fully secure them towards the end to allow for later adjustments.
- Step 3: Follow the instructions step by step, sorting the parts according to numbers or diagrams to avoid mix-ups.
- Step 4: For drawers, be sure to pay attention to the correct alignment of the runners; improper installation can cause sticking or wobbling.
Finally, an important tip: For some screws or dowels, it is beneficial to add a bit of wood glue during the initial assembly, as this significantly improves stability.
jelite
7 Mar 2020 08:47
I would like to add that door alignment often causes problems. These are usually the result of slightly uneven drilling or not positioning the hinges precisely.
Daledra schrieb:
The drill holes often don’t line up exactly, which causes misaligned parts.
That’s exactly why I recommend checking with a spirit level or a digital angle gauge before fully tightening the screws to ensure everything is straight. Small adjustments during assembly often prevent costly corrections later on.
Another common mistake is overlooking small but crucial intermediate components in the instructions, such as spacers or plastic sleeves, which are important for the stable and quiet operation of drawers.
praWarre69
7 Mar 2020 14:15
I think with IKEA Hemnes, you should always expect a little adventure – the parts don’t always want to go together the way you’d like! 😄
But seriously, what helped me is patience and a good sense of humor when a screw won’t turn or the instructions feel like a mysterious puzzle. Sometimes little tricks help, like:
- lubricating screws with a bit of wax or soap,
- using tools like pliers for a better grip,
- and taking breaks instead of getting frustrated.
Because honestly, if it doesn’t work out, we all have fun anyway! 😉
Jaime
8 Mar 2020 09:02
From my experience, one of the main assembly issues with IKEA Hemnes is the quality of the supplied screws and dowels. These often do not provide a secure hold after being tightened multiple times, leading to instability. Therefore, it is advisable to have better quality fasteners on hand to address any problems that may arise.
taudi schrieb:
Some screws or dowels should be supplemented with a bit of wood glue during the initial assembly, which significantly improves stability.
I fully agree with this – wood glue combined with good screws noticeably extends the furniture’s durability.
Additionally, I recommend checking all parts for warping before assembly, as wood naturally tends to move slightly, which can affect the fit.
