ᐅ What are your experiences with the IKEA Brimnes drawer slides?
Created on: 20 Feb 2019 18:47
KEOPETRA
KEOPETRA
20 Feb 2019 18:47
I am interested in hearing about your personal experiences with the drawer slides in the IKEA Brimnes furniture series. Specifically, I am concerned about the quality and durability of the runners, as I have often encountered issues with sticking or squeaking drawers in other furniture with similar slide systems. Are there any particular points to consider during installation of the Brimnes drawers, or do you have suggestions for improvements to ensure their long-term smooth operation? Reports on wear and tear after extended use or tips for retrofitting would also be very helpful. Perhaps someone can also provide advice on alternative or better replacement slides that are compatible? I look forward to your practical insights and any critical feedback.
PLOMA
20 Feb 2019 19:26
Your question hits the mark, especially the focus on installation and wear!
I have been using several Brimnes dressers myself for about three years, and I have noticed a few things regarding the drawer slides:
- The original slides are made of stamped steel with glued-on plastic gliders. This initially provides fairly smooth operation, but the sliding components are not particularly durable.
- Precise alignment during installation is essential; even a slight misalignment can cause jamming quickly.
- One common issue I have observed is that over time, the small plastic parts wear down or shift slightly, leading to sticking movements.
- Therefore, I recommend paying close attention to exact parallelism during installation and using enough screws at weak points.
- If problems arise, some DIYers have extended the lifespan noticeably by applying sliding bearings or silicone grease during repairs.
Regarding replacement slides: Some users swap them for higher-quality full-extension slides, but compatibility with the original drill holes is limited. Modifying the cabinet is often necessary then.
I’m curious whether you have already assembled the furniture and if the drawers are already showing issues there? With frequent opening and closing, especially with heavy contents, the weaknesses become apparent fastest.
Ryker66
20 Feb 2019 20:33
PLOMA schrieb:
Precise alignment during installation is essential; even a slight tilt can cause it to jam quickly.
That's correct, just install it straight and everything works smoothly. I have had no issues after more than 2 years. No squeaking or sticking. It only makes sense to slightly retighten the screws after some time.
klo40
21 Feb 2019 07:11
In addition to the previous posts, I would like to provide a structured guide on how to maintain the Brimnes drawer slides permanently and avoid potential issues:
- First: The slides are not fully ball-bearing but are based on plastic gliders, which means that wear will occur from the start if installed incorrectly or under heavy load.
- Installation tip: When attaching the drawer and the slide to the cabinet body, ensure exact vertical alignment. Small inaccuracies can significantly affect smooth operation.
- After assembly: The drawer should slide smoothly without resistance or squeaking. If not, remove it and check whether the gliders are firmly seated or if screws are too tight or too loose.
- Maintenance: Use a fine silicone spray or a dry lubricant (no oil!) on the slide to reduce noise and friction.
- Load capacity: The maximum load for the Brimnes slides is about 15–20 kg (33–44 lbs) per drawer. Avoid storing heavy items here.
- After wear: Replace the plastic gliders or use suitable spare parts if available.
Summary: With clean installation and careful use, the drawers will last a long time. Shorter service life usually results from incorrect fitting or overloading. For a more comfortable experience, investing in higher-quality slides is possible but requires additional effort.
