Hello everyone, I have a problem with my Ikea Brimnes drawers, which start to squeak after some time of use. My question is: How can I prevent my Ikea Brimnes drawers from squeaking? I have already cleaned the drawers and checked to make sure there are no obvious foreign objects in the sliding mechanism, but the squeaking continues. I am interested to know if there are specific care instructions, lubricants, or adjustments recommended for this piece of furniture, without damaging the mechanism. I look forward to your experiences and tips!
From a technical perspective, squeaking in the Brimnes drawer usually results from insufficiently lubricated sliding surfaces or foreign material in the track area.
To address the issue effectively, I recommend the following steps:
- Fully pull out and remove the drawer.
- Manually clean the runners from dust and fibers, preferably with a brush or a dry cloth.
- Check the plastic rollers for damage, as cracks or brittle spots can reduce smooth operation.
- Then apply a PTFE-based (Teflon) lubricant to the tracks and rollers. This substance reduces friction and is safe for plastic.
I advise against using oily or greasy lubricants, as they attract dirt and can worsen the problem over time.
KIN42 schrieb:
If the rollers are extremely worn out, replacement might also be advisable.Good tip. How can you actually tell when the plastic rollers of a Brimnes drawer really need to be replaced? Are there typical signs besides squeaking, such as play or uneven movement?
jamar35 schrieb:
Are there typical signs besides squeaking, such as play or uneven movement?Yes, exactly. In addition to squeaking, you should look out for the following symptoms:
- The drawer moves stiffly or catches during operation.
- Visible play or wobbling occurs when pulling out the drawer.
- The rollers make irregular noises, or parts of the drawer sag slightly.
If the drawer does not close properly or becomes misaligned, this is often a sign of worn rollers or damaged guide rails.
If you need replacement rollers, Ikea sometimes offers these as spare parts, otherwise, universal rollers are available at furniture stores.
FAVALERIE93 Aug 2022 12:53One more tip: If you already have the drawers apart, also check whether the screws on the drawer slides are tight. Loose screws can cause noise.
I had the same problem, and it was really frustrating. What helped me was cleaning the screws and guides thoroughly and then applying a very thin layer of PTFE spray. It was important to completely remove the drawer and clean everything patiently, as there was a lot of dust and lint inside.
It can be annoying to deal with squeaky furniture all the time, so I hope these tips help you. If you want, I can explain in more detail how I went about it.
Joe52 schrieb:
I had the same problem, and it was really annoying.Thanks, that already sounds good. If you like, a more detailed description of your approach would definitely be helpful. I’m curious whether you disassembled the drawers or if cleaning the moving parts was sufficient.
