ᐅ What are the most common damages to Billy bookcases caused by incorrect assembly?
Created on: 19 Feb 2021 08:17
henrik50
I have a question that might be interesting for many people assembling Billy shelves: What are the most common damages that occur when these shelves are assembled incorrectly? Specifically, I am interested in which components are most vulnerable, whether there are typical assembly mistakes, and how these affect the stability and lifespan of the shelf. Has anyone had experience with the most frequent assembly damages and can offer tips on how to avoid them?
henrik50
19 Feb 2021 11:31
KAMERON schrieb:
Worn-out or damaged drilled holes caused by excessive force during screw connections.
That’s interesting, as I have noticed that sometimes screws fit quite loosely during assembly, and then the holes get damaged if more force is applied. Is there any recommendation on how to prevent this without risking the stability of the shelf?
hauklo
20 Feb 2021 08:57
henrik50 schrieb:
Is there a recommendation on how to prevent this without risking the shelf becoming unstable?
Yes, the best method is to lightly roughen the dowel holes before screwing in, and to carefully drive the screws in—ideally using a cordless drill at low speed. Tighten until the connection is secure, but not fully forceful. If the fit is too loose, a drop of wood glue on the dowels can help strengthen the connection without damaging the wood.
Ixfu2
20 Feb 2021 09:22
With my Billy shelves, I noticed that improperly aligned shelves often sag. This is usually because the row of holes is not used precisely. Correct placement of the shelf supports is therefore crucial to prevent damage to the recesses and shelves.
Leonardteo
20 Feb 2021 09:59
Ixfu2 schrieb:
Correct installation of shelf supports is therefore crucial to avoid damage to cutouts and shelves.
Good point. I would add that a common mistake is overloading the shelves, especially in long shelving units without a central support. The resulting stress often leads to sagging shelves or worn edges. It is worth installing additional supports in such cases.
