ᐅ What alternatives are available to Ikea PAX for custom-built shelving systems?
Created on: 1 Aug 2022 10:32
Go-franz8G
Go-franz81 Aug 2022 10:32Hello everyone, I am currently considering building a custom shelving system as an alternative to the Ikea PAX system. There are several reasons: although PAX is modular and popular, I often find the design flexibility limited, some materials are too thin for my taste, and the standard dimensions don’t quite fit the space I want to use.
My question is: What alternatives to Ikea PAX do you know of, especially regarding DIY shelving systems that focus more on customization, stronger materials, and adjustable dimensions? Recommendations on suitable materials, joining methods, and tips for stability with freestanding units would also be very helpful.
I look forward to your experiences and advice!
There are many alternatives to PAX, especially in the area of modular shelving systems. Check out systems from USM Haller or Modulor, which offer modular solutions that are more sturdy and customizable.
For DIY: Connect plywood panels using biscuits or dowels. This method is stable and relatively simple.
Your question about alternatives to Ikea PAX for self-built shelving systems is very well focused. I would recommend first considering the base material – plywood or solid wood offer significantly higher stability compared to particleboard, which is often used by Ikea.
If you want a flexible design, a tongue-and-groove system with biscuits for gluing is a good option. This allows you to divide the surface into modules easily, and later you can move or add shelves as needed.
A commonly underestimated issue is stability with freestanding shelving systems, especially if you are building tall units. Therefore, I recommend treating the back panel not just as a cover but also as a load-bearing element – a sturdy plywood board at least 8 mm (0.3 inches) thick is usually sufficient.
Additionally, you should consider zinc plating or metal brackets at the corners, especially if you plan to store heavy loads.
What materials or construction methods are you considering exactly? What kind of loads do you expect the shelving to bear?
Go-franz81 Aug 2022 11:58PLOMA schrieb:
Your question about alternatives to Ikea PAX for self-built shelving systems hits the mark perfectly.Thanks for this assessment! I am currently leaning towards plywood, as I find its quality somewhat superior and less prone to swelling. The loads are between 5 and 15 kg per shelf (approximately 11 to 33 lbs), mainly books and some decorative items.
In terms of connections, I am interested in so-called perforated plates or perforated panels, which can be fitted with dowels or bolts to create modular elements with flexible configurations.
How durable are these systems in practice? Are there any experiences regarding their longevity and load-bearing capacity? Would such a system also be suitable as a room divider?
Perforated panels or pegboards used as connecting elements are generally a very flexible solution. It is important that these panels are made from a high-density engineered wood material, such as MDF with a melamine coating. This type of surface offers good resistance to abrasion and prevents the holes from deforming quickly.
For load capacity, it is essential to follow the manufacturer’s recommendations, especially concerning the spacers or bolts. Depending on the height of the shelving, I recommend stabilizing the system with cross braces or metal-reinforced connectors. Without these reinforcements, tall shelving units tend to tip over or warp.
Regarding room dividers: If designed attractively and if the connection is loose enough, this type of solution can be an effective room separator. However, it may be better suited for lighter loads rather than as a bookshelf carrying loads close to the maximum capacity.
Go-franz8 schrieb:
From a connection standpoint, I’m interested in so-called perforated plates or perforated walls, which can be equipped with anchors or bolts to create modular elements with variable configurations.I consider this an elegant solution, but I wonder whether this flexibility might compromise stability. It’s important to critically assess how well the connections actually hold, especially when different load patterns occur. I have experimented with modular systems myself in my workshop and found that frequent movements at the connection points can lead to a certain loosening effect over time.
My recommendation: If you rely on modular and flexible systems, be sure to invest in high-quality fasteners and carefully check the load distribution. Otherwise, the supposed advantage of a precise, adaptable unit is quickly lost in practice.
