ᐅ Venetian Blinds and Roller Shutter Motors – Is It Possible to Retrofit Wireless Remote Control?
Created on: 16 Jan 2020 11:08
Golfi90Hello everyone!
Our venetian blinds and roller shutters are operated conventionally with a switch.
Now I thought it would be nice to be able to operate some of the venetian blinds and roller shutters ADDITIONALLY by remote control.
Is there a way to retrofit this?
The switch should remain and continue to function normally...
Yes, for example, Eltako wireless shutter actuators. These are installed behind the switch, provided there is enough space in the wall box. Approximately 50€ per unit.
Otherwise, there are also many options in the Chinese budget smart home segment, like Shellys and similar devices. These operate via Wi-Fi. You will also need a server for remote control through an app.
There will be more examples to come. KNX-RF could also be an option.
brotpeter16 Jan 2020 12:37Take a look at the 2.5 version Shellys. They cost about 20 euros each and usually fit easily behind a switch (if it’s installed in a deep flush-mounted box).
I have installed these actuators on all the roller shutters in the house and can now conveniently control them via an app. They have been running very reliably for months. The Shellys natively offer the option to perform timed actions (for example, open or close based on sunrise, etc.) or to link all devices in a room, floor, or the entire house together in groups.
What you do need near the switches, however, is an L (live), N (neutral), and, of course, Wi-Fi reception...
brotpeter schrieb:
What you do need near the switches, however, is an L (live), N (neutral), and of course Wi-Fi reception...Wi-Fi reception would definitely be available.
Unfortunately, I’m not sure about the live and neutral wires. The roller shutter switches are installed individually, not in a triple frame or anything like that. Are live and neutral typically included there? I have no knowledge of electrical work!
brotpeter16 Jan 2020 14:22Golfi90 schrieb:
Unfortunately, I don’t know how the live and neutral wires are arranged. The switches for the roller shutters are installed individually—not in a triple frame or similar. Just remove one switch and check what cables are there... it’s quick to verify. Then you can decide how to proceed. But make sure to turn off the circuit breaker for the room first.
Golfi90 schrieb:
Is live (L) and neutral (N) typically included there? I have no knowledge of electrical work! I can’t say if that’s standard. If you don’t know anything about electrical work, it’s better to stay away.
