ᐅ Venetian Blinds and Roller Shutter Motors – Is It Possible to Retrofit Wireless Remote Control?
Created on: 16 Jan 2020 11:08
Golfi90
Hello everyone!
Our venetian blinds and roller shutters are operated conventionally with a switch.
Now I thought it would be nice to be able to operate some of the venetian blinds and roller shutters ADDITIONALLY by remote control.
Is there a way to retrofit this?
The switch should remain and continue to function normally...
guckuck2
16 Jan 2020 14:27
Without a live wire, the switch couldn’t control anything with conventional wiring....
fragg
16 Jan 2020 17:19
guckuck2 schrieb:
Without a live wire, a switch in a conventional wiring setup couldn’t control anything ....
Yes and no. The question is not about the live wire, but about the neutral conductor.
It depends on how the motor is wired. In my electrical setup, I insisted that all three conductors are present – there are installations where the neutral conductor only goes as far as the motor.
guckuck2
16 Jan 2020 17:25
fragg schrieb:
Yes and no. The question isn’t about the phase conductor but the neutral conductor.
It depends on how the motor is wired. For my electrical setup, I insisted that all three lines be present—there are electrical installations where the neutral conductor only runs up to the motor.
Well, theoretically you could run a single conductor there. But does anyone really do that?!
NYM 3x1.5mm (3x0.0059 inches) cables make up the majority in conventional electrical installations.
fragg
17 Jan 2020 08:28
guckuck2 schrieb:
Well, theoretically you could lay a single conductor there. Does anyone really do that?!
NYM 3x1.5mm (3x0.06 inches) cables make up the majority in conventional electrical installations.
yes. Tip into Google "roller shutter switch without" and see what it suggests as a search term :P
guckuck2
17 Jan 2020 08:40
fragg schrieb:
Yes. Type into Google "roller shutter switch without" and see what suggestions come up as search terms
Just because the switch doesn’t require a neutral wire doesn’t mean that a cable with only a single live conductor was pulled there. That’s what I’m trying to say. The electrician has a roll of NYM 3x1.5mm cable and uses a few hundred meters of it in a single-family house. And for roller shutter switches, they come with a different cable just for that purpose?
That would be incredibly foolish. But it can’t be completely ruled out, yes.
The original poster will probably have to check that themselves.
fragg
17 Jan 2020 09:00
guckuck2 schrieb:
Just because the switch doesn’t require a neutral conductor doesn’t mean the cable pulled there has only a single live wire. That’s what I’m trying to say. The electrician uses standard NYM cable 3x1.5mm and installs a few hundred meters of it in a single-family house. And then for the roller shutter switch, he brings a different cable just for that purpose?
That would be ridiculously stupid. But it can’t be ruled out, yes.
The original poster will have to check this themselves.
They usually take the cables from the roller shutter motor, those are long enough.
Take a look inside your setup.
I insisted on this and have all three wires down there, but not all are standard installation cables; some are thinner copper-stranded ones. The ones from the motor.
I also paid a flat extra 200€ for all the flush-mounted boxes to be deep boxes, or even double-deep... otherwise, the cluster of Wago connectors wouldn’t fit behind the wireless switch at all...
